Question about Kitchen Ranges
Do you sell viking meat probes for oven model ve50530ss viking part pe050114
the dr
  • 447 Answers
SOURCE: meat probe button on control pad
there is no real way to reset it you reset it when you turned the breaker off, It sounds like the EOC (electronic oven control) is faulty. I would just keep reset it and keep doing that to bake the turkey how hot will it get before it buzzes? is it showing any error codes?? F1, F2, F3 etc.....
Posted on Sep 30, 2007
SOURCE: meat probe problem
Replace the oven sensor
Posted on May 11, 2008
SOURCE: KitchenAid Meat Probe
Unplug the range and remove the back middle part of the back (should be three screws, I did this yesterday). Remove the rigth side panel by pushing from the back of the range to the front about an inch. It should then be possible to lean the top out and then remove.
Where the probe enters the oven you should see a whole in the side of the oven. If you look carefully you will see the other end of your broken probe sticking out in the open (You may have to move some insulation to see it).
Push the probe back into the oven san you should be back in business.
Replace range side and back (make sure to replace any insulatin which you have moved.
Posted on Apr 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: Meat Probe doesn't work
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question%^YTG
Posted on Oct 01, 2010
jturcotte
  • 8732 Answers
SOURCE: How do I access the
Do you have the gas range?
Figure below shows the probe clipped under the grille. You remove the grates and grate supports, then lift the grille a few inches to access the probe. Before removing, note the position and orientation and make sure to put it back the same way.
If this is not the right oven, please reply with or enter a new request with oven model number.
Posted on Dec 08, 2010
F3E3 Meat probe Shorted
faulty meat probe, probably a factory defect, if still covered by warranty, return oven for replacement.
Mar 22, 2014 | Jenn-Air 27 in. Electric Single Wall Oven...
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
My oven is stuck in probe mode and will not cancel.. what should i do
Measure the resistance of the meat probe on the K-ohm setting. If it's open, then the probe is bad. I'm not finding a spec on the resistance but it should be something in the K-ohm range.
Next stop is to check the meat probe socket. May be gunked up with condensed grease or whatever. Sometimes a light schmear is all it takes to flake it out. Then check continuity from each leg of the meat probe socket back to the ERC, where the meat probe harness connects.
Mar 06, 2010 | Ovens
What is button on the left next to plug outlet on kenmore c880???
As far as i can tell by your model there is no button there is only a meat probe receptacle. if yours doesn't have such a thing it is likely to be an after market part. part number for the meat probe is WB20X5050. hope this helps
Thanks
Oct 11, 2009 | GE Profile JTP56 Electric Double Oven
What is a U80 meat probe error and how do I fix it?
Error U80: Shorted meat probe
1) Food, moisture, or other substance is in the socket or on the oven connection end of the meat probe. Check: Verify proper operation with new probe (replace probe). If still fails with new probe check wiring of housing to eliminate shorting to sheet metal. Solution: Clean socket and meat probe.
2) Bad meat probe (shorted). Check:Use new meat probe to test for correct values in the service screens. Solution: Replace meat probe.
3) Shorted socket or wiring. Check: Test socket at connector J20 on relay board. Solution: Replace meat probe socket.
Functionality when error U80 reported: Cooking and cleaning are available but meat probe options will not be available.
User action/solution:
1) Verify oven connection end of meat probe is clean and no food, moisture or other substance in is the meat probe socket.
2) Call for service.
Aug 26, 2009 | Dacor Epicure EO230 Stainless Steel Oven
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
Jan 31, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Meat probe button on control pad
Sep 30, 2007 | Jenn-Air JES9860 Electric Kitchen Range
Kitchen Ranges Logo
51 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
