Question about Spectrum Technical Hifi EQ-B5200 Professional Equalizer with (Black) Home Equalizer
Conect eq. with the turntable
Hello, can u let me know how can I connect Technics equaliser SH-8045 with Tech.turntable to Technics amplifier VU-V2?Thx Vlad
  • 33 Answers
Hi there, first you have to pit your turntable phono at the pre - amp phono to amplified then after you can put now direct into your equalizer and then to your amplifier
Posted on Jul 09, 2009
  • djsherwin_29 Jul 09, 2009
    first you have to put your phono turntable at
    pre-amp phono then put in your equalizer then in your amplifier...
    ( note: the pre- amp phono will amplified the small signal coming from the records)...
Would I be able to connect an external Technics SH-8036 Stereo Graphic Equalizer to my Technics SA-500 receiver?
Yes, it is hooked up using the (cassette) tape inputs and outputs. Use the tape monitor switch on the receiver to switch the EQ in or out.
Feb 11, 2016 | Panasonic Technics Sa-dx930 A/v Stereo...
Hooking up EQ to RECIEVER for a TECHNICS MODEL SH-8017
You'll need 4 connections total. On my integrated amp, I connected the four connections to all Line In and Line Out ports. And the other ends into the tape 2/EXTRA ports respectively.
Jul 19, 2013 | Panasonic Technics Stereo Graphic...
Connect a denon amplifier pm-510ae to a technics equaliser sh-8058
Hi Just to let you know what ever you put between the amp and speaker you will degrade the sound quality. Even with the best machines you will muddy the sound. If you read HiFI magizine they will tell you this is true.
But if you don't care about the quality of sound than go ahead hook an equalizer on it. Hope that helps you.
Mar 27, 2012 | Denon Audio Players & Recorders
Following a split from my boyfriend I really need some help in how to connect up my hifi system. It's all technics Tuner Receiver ST 610L Equaliser SH GE70 Amp SU V470 CD Changer SL...
the amp should have an in and out for the cassette player also,, so you would go from the Out on the receiver, to the in on the cassette,, and out of the cassette to the in on the receiver, I don't have nor can I locate that EQ , but basically,, you need to come out of the eq and back the same way you would a Cassette player,,
Jun 14, 2011 | Technics SH-GE70 Home Equalizer
How do i connect my technics su7700 amp to my technics sh8020 equaliser
Like any sound processor, in the tape loop...
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec or Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play or Line-Out.
Feb 15, 2011 | Audio Players & Recorders
Technics SL-1210Mk2 Sound is very clear but low frequencies are very POOR.Other sources are checked i think the problem comes from the turntable. I replace my old phono pre amp with rolls VP29 and i check...
Possible that the negative feedback amplification is not compensating to the preamp.
The cartridges must match with the preamp so that the full frequency response is received.
If you can add along an equaliser to you phono path on way to the amplifier , the compensation can be set up to the room accoustics and taste.
Alteration of the input impedance to the amplifier with a network can also help but an equaliser might be tthe best for you
Sep 15, 2010 | Technics Audio Players & Recorders
Connection of Amp to Equaliser
Thanks guys, but i solved my problem, i experimented and decided that i would run my DVD player (Aux Out) as a CD player through the Equaliser in [Rec] and from equaliser out [Play] i went into Tape Play on Amp, then i connected my Turntable CD Radio System to the Tape 1 Rec on Equaliser and then from Tape 1 Play on Equaliser went into the Tape 2 on AMP then i could use Aux in on Amp to connect my Laptop via my laptops headphone socket my laptop has an equaliser so i didn't need to connect to pioneer EQ, i also connected a small 5.1 to the DVD's 5.1 and connected 4 *45w Speakers to the AMP. and i can say it was FANTASTIC i couldn't get to 5 on my volume it was un @$#%believable.
My Quote
"Where there's an In, there's an Out".
Aug 30, 2008 | Audio Players & Recorders
Technics SH-8017 Equalizer
use youe tape out signal into the eq's main input and the eq'sout back into the record side of ur tape source.
Jul 28, 2008 | Audio Players & Recorders
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Connection between CD, EQ, SP technics
Each unit (the EQ and the Processor) should have left/right in/out rca jacks as well as L/R tape in/outs. The EQ or processor use the receiver's tape loop and then provide a tape loop to replace the one they've used on the receiver.
You plug the first unit (let's say the Sound Processor into your receiver/amp as if it were a tape deck (Processor's outs connect to reciever's tape ins (play) while the Processor's ins connect to the receiver's tape outs (record).
Then you chain the EQ off the Processor in the same way (EQ outs connect to Processor's tape ins (play) and EQ ins connect to the Processor's tape outs (record).
Last you connect the tape deck to the EQ as follows. Tape deck outs connect to EQ's tape ins (play) and the tape deck ins connect to the EQ's outs (record).
This will put both the Sound Processor and the EQ in the receiver's tape loop. In order to have all the receiver's source signals routed through them you may have to engage a Tape Monitor switch or button somwhere on your amp which will route the tape loop to your speakers.
Jan 09, 2008 | Technics RS-TR272 Single Cassette Deck
202 people viewed this question
Top Spectrum Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Spectrum Audio Player and Recorder Expert? Answer questions, earn points and help others
