Question about D-Link DIR-625 (790069292637) Wireless Router
Problem between my Qwest actiontec modem and D-link router
I followed the installation instructions for my D-link router, connecting it to my Qwest actiontec modem and my computer and ran the set-up wizard, but my internet connection failed. I tried troubleshooting with Network Magic, and followed the instructions on the automatic message when I called tech support, but nothing has worked. The network seems fine because my laptop picks up the signal and will connect to the network, but I can't get internet access.
  • 1 more comment
  • Claudia Essig
    Claudia Essig Jan 08, 2009
    My desk top computer shows I have an internet connection, but I can't get on the internet or my get my emails. It works sometimes then goes off. There is a signal, as my wireless laptop can use the connection.
  • Mcegan2000 Jan 21, 2009
    I have the same problem between the router and my laptop. The laptop is connected to the wireless network, but cannot access the internet. In the TCP/IP I gave the laptop the IP address the router assigned to it. Gateway is the router IP address. What else do I need to do?
  • akku_sd007 May 11, 2010
    check the ip address,default gateway what you given in router and what is in your modem
  • 20 Answers
You need to sign into the dlink router and check the status tab, to make sure that the router has picked up the modems IP address. it sound like it hasn't, and is just assigning lan IPs to the client machines, butd oes not have a valid WAN IP to the internet.
If it hasnt got a wan ip, you want to do a hard boot on the router .unplug the router ONLY for 30 sec, and power back up the router only ...not the modem this should allow the router to find the modem IP
Posted on Feb 16, 2009
Where can I get a quest m1000 mnual for a quest m1000 modem
Here's a link to the quick setup guide:
http://setuprouter.com/router/qwest/m1000/manual-596.pdf
and Centurylink help site:
M1000 Actiontec Modems
Note: Google searching for actual .pdf manual results in links to hacker sites, be careful.
Nov 11, 2014 | Actiontec M1000 Dsl Wifi Modem In Box W/...
How do I reset the password and User ID on an Q1000 Actiontec Modem?
Things You'll Need
• Q1000 Qwest Wireless N VDSL Modem Router
• Computer connected to the Modem
Step1 On any computer that is
connected to the Internet, type http://192.168.0.1 in the web
browser window and then press Enter.
Step2 Click Utilities.
Step3 elect "Restore Defaults" from the menu on the left.
Step4 Click the last restore button that follows
"Restore Modem to Factory Default State
The manufacturers web site with this advice is here.
http://www.actiontec.com/products/datasheets/Q1000QwFactoryDefaultsHowto.pdf
Sep 24, 2014 | Actiontec Qwest Model Q1000 4-port...
How do i conect to my wirless router setup
MAKE SURE THAT YOUR LANDLINE IS CONNECTED TO YOUR WIRELESS AND THEN FOLLOW THE INSTRUCTIONS ON THE DISC
Jul 23, 2012 | Actiontec Qwest Branded - Centurylink...
I am trying to connect a D-Link DIR-628 router to a Qwest Actiontec GT-701-WG DSL modem. My computer OS is windows XP-service pack 3. The modem works fine when connected directly to the computer and...
Plug your internet into the router then, the router to the computer. Go to your network settings and run the network setup. This will change the settings in windows to except the router into the network. You may have to restart the computer. This should give you internet access to your computer through your router.
Jan 27, 2011 | D-Link Computers & Internet
I have an Actiontec wireless modem from Qwest and I cannot find the SSID
If you haven't changed your SSID, the default SSID is provided on a sticker on the bottom of your Actiontec router. It usually starts with a JR
Nov 10, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I have the actiontec gt704wg dsl modem that I got from Qwest. The last few months I often lose my internet connection. The only way I get it back is by turning the modem off for a few seconds and then...
It sounds like a firmware issue or problem. Have you tried updating the firmware of the router? If not, download the latest firmware from actiontec website and install it to your router. Note: After successfully updating the firmware, you need to hard reset the router. Press the reset button at the back of the router for 30 second then unplug the power for 30 seconds as well then plug it back n.
Oct 06, 2009 | Actiontec GT704WG Wireless Router...
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use 192.168.0.1 as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as 10.150.1.1 for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Red internet light stays on
the following link provides some very streightforward advise;
http://www.qwest.com/internethelp/modems/gt701/pdf/13566_GT701_ServiceStatus_031906msl.pdf
check the following in order
1 check that all of the cables are securely plugged in, if you find any loose plug them back in, you may need to powercycle the router afterwards though if the router is subsquently plugged into another unit down the chain power off both units turn them back on turning on the actiontec last.
2 if your ISP requires logon details to be included in your router, double check by viewing your router settings renter them if you are unsure.
3 lastly, have you paid your ISP bill?
Nov 05, 2008 | Actiontec GT701WG Router (actiongt701wg)
I cant communicate with belkin wireless g router
It sounds like you don't have the units connected properly. Make sure you have a cable(wired) from your ethernet card on your pc connected to a wired port on the router. Then plug your router from its yellow port into the modem. Make sure your modem is connected to its Internet interface. Plug in your modem and wait 60 seconds for it to power up. Then power up the router.
At this point you should be able to access the router with the supplied installation CD. Run the setup assistant and it will define your wireless network. When you are through you should have internet access through the wired network. When you are finished you should be able to use the wireless network assuming you have the card installed correctly and the software for the card correctly installed.
Jul 09, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link DIR-625 (790069292637) Wireless Router Logo
471 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
