Question about Onkyo TX-DS777
The reciever just shuts down
This is on Onkyo AV Reciever TX-DS77 SN#606R072657. When ever I turn the unit on you hear a click and then the reciever just powers off. I can't get no sound to come out of it. For a short time it would play and then when it heats up it shuts itself off now all it does is shuts itself off. Can you please give me some information on how to address this problem.
  • brigittesesp Feb 03, 2009
    have the same problem with the TS-SR 674
The manual suggests disconnecting inputs and outputs and power, letting it sit for an hour, then plugging it back in and turning volume to max to see if it still shuts off. If it does, the problem is with the unit. If it doesn't, the problem is elsewhere.
Judging from some other sites, this is a common problem. If you take it to a dealer, suggest they check the AC input. Before anything else, make sure that there are no stray wires on your speakers connecting the positive and negative clips, which will cause a short and activate the amp protection.
I had the same problem with an Onky502 and replaced it today with an Onkyo606. It worked fine for an hour then started shutting off automatically. I'm following the manual and letting it cool off now for an hour, and meantime I'll check my speakers.
Posted on Mar 05, 2009
  • mcswill Mar 06, 2009
    After letting the disconnected rcvr cool I plugged it back in and turned the gain to max. It didn't shut down. So I checked the wires at the speaker connections on the back of the unit. They all looked okay except on, which had the insulation sheared off for about half an inch in a place where it might have been in contact with another wire or with ground. I reclipped the wire, stripped it carefully, and reinserted it into the speaker outlets. Since then the Onkyo SR606 has worked just as it's supposed to for two days.
    I'm beginning to feel like a moron for not having checked for that simple problem on the previous unit.
Im Need Help Resetting My ONKYO TX-SR6O3X RECIEVER Its By Itself Or The Owners Manual to Help me reset it
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
Onkyo AV Receiver TX-SR503 While sleeping with earphones connected, the receiver shut down and the standby light blinked. I unplugged the power cord, reconnected power and the receiver shut down...
Have you provided adequate ventilation?
May be your receiver is running hot and when there is loud volume it is obviously getting overloaded. There are no fans inside 674, the only way to provide good ventilation is to keep the top of receiver clear for atleast 6 to 8 inches.
Hope that helps.....
Jul 03, 2008 | Onkyo Audio Players & Recorders
Pioneer VSX-3800 shuts off
I have this same problem mike. have you founf any solutions yet?
I have a heck of a time turning my reciever on and when it does turn on I try to change the channel only to have my unit shut off on me! any help would be great.
Spriggs032@gmail.com
Mar 29, 2009 | Onkyo TX-DS575 Receiver
Onkyo TX-DS777 goes straight to protection mode
Hello.You have shorted audio outputs. One of your channels has shorted output transistors. If your unit uses output ICs then one of them is shorted. Both types ( individual transistors or ICs ) are located on the large finned heat sink. The parts are available from http:\\www.tritronicsinc.com. good luck
barneyluc
Oct 19, 2008 | Onkyo TX-DS777
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
No audio
Most of the time its the amps that are bad and need changing. This will be transistors on heatsink in the reciever. Part number should be on the amp.
Sep 19, 2007 | Onkyo TX-DS494 Receiver
Subtitle Problem: Onkyo TX-sr605
The only remote that will definitely turn the sat subtitles on/off is the sat remote. The other subtitle buttons on the other remotes refer to the DVD subtitles and the subtitles generated by the tuner in the tv. The subtitle option is greyed out on the tv because you are not on the tv tuner.
Sep 03, 2007 | Onkyo TX-SR604 Receiver
TX-DS575 reciever
Normally you hear a clicking sound coming from the inside when you turn on your amp. That's the sound of the magnetic circuit breaker (switch). If you tap your amp to turn it on, and if the amp gets turned on after you did it:), then I suppose the problem is on the relevant switch.
Jul 04, 2007 | Onkyo TX-DS575 Receiver
Onkyo TX-DS777 Logo
372 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
