Question about Jenn-Air 30 in. CCE3401 Electric Cooktop
  • Anonymous Apr 02, 2009
    I don't want to hurt the cook top but can I use a cast iron skillet on it?
  • Jenn-Air Master
  • 2,651 Answers
You CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Posted on Jan 10, 2009
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Jenn Aire Cook top
try national parts depot
or look for new knobs that matches the fit and change the broken one or all of them.
Jul 08, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
Jenn-air CCE3401 Radiant cooktop one burner takes a long time to heat. has since purchase.Advise
Turn off range circuit breaker.
Remove burner and measure the connections across it. See how many Ohms you get.
Do the same to an identical sized burner which works well and measure its resistance. If the numbers differ considerably the burner needs replacement.
You had mentioned you own a 'radiant' cook top which implies a glass type top, in that situation you may need to pull the oven out to get to the rear connections.
If you decide to continue on this project you may have to pull out the lowest drawer, this will expose the safety bracket which prevents the complete oven from falling over and hurting anyone who may lean inadvertently on the oven door and cause it to tilt forwards.
When the oven is slid to the front the first 5-6 inches keep it from tilting. This is mentioned now because once the oven is removed and is pushed back towards the wall afterwards, the bracket may not align properly and you may be puzzled as to why you can't move it back. In addition there may be a crowfoot connection (voltage) which needs to be disconnected if it's not long enough for access.
Most ovens have a folded piece of paper in the rear which shows the schematic diagram. This is sometimes in a clear bag which sticks permanently to the oven. It's meant for the service technician.
When the oven is removed and looked at from the rear a plate just below the burners may have to be unscrewed. This will show the various electrical connections. See the schematic for help...and
before you undertake such a task, I'd suggest you would look on You-Tube on checking burners, etc. It may stop you in your tracks and get a serviceman to help you.
There is a company called Appliance Zone which I used for my microwave front panel replacement. They carry everything for large appliances.
They are good for parts and general assistance.
If you have and use a VOM at home you seem to realize on how to apply your talents, otherwise I would consider getting professional help.
Feb 02, 2015 | Jenn-Air Cooktops
I have a Jen Air gas cook top that wont stop sparking when i turn burner on
make sure there is not a build up of oil or grease
under ignighter
Dec 20, 2013 | Cooktops
Want to clean electric cook top glass
Watch the provided video on the cleaning procedure for glass cook tops.
Jan 21, 2012 | Jenn-Air JED8430 Electric Cooktop
What is the best way to clean the cast iron top on the gas cook top? Thank you
Soak in hot water/detergent for about 1 hour - then use a mild abrasive plastic brush... and when done - thinly coat with olive oil or similar.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 03, 2010 | Amana AKS3040BSSCooktop
Parts Replacement
twist the burner to releace them . remove all 4 and the screws around the sides the lift top .. cook tops have to be completly disambled . for service .. mm
Jun 29, 2010 | Maytag MGC5430BDS Gas Cooktop
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
Gas stovetop burner - continuous clicking
Sep 18, 2008 | Cooktops
Jenn-Air 30 in. CCE3401 Electric Cooktop Logo
868 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
