Question about Brother MFC-7440N Laser Printer
Can't get the printer to terminate a fax transmission...so having to waste 50 pages sometimes b/c the stop cancel button doesn't work to stop a fax from sending...cancel button doesn't work..taking paper out just saves it for later .....can it be stopped???
  • 3 Answers
Power off, power on? Unplug the phone line?
Posted on Feb 12, 2009
How to erase memory in Brother 8690 MFC - it keeps printing unwanted faxes which are stored in the memory! It is junk mail and 20 pages long and I want to cancel it. When I press "Stop" and pull the power...
Try to press and hold Job Cancel button until a message Job Cancel (All) appears. Press OK to confirm.
If not working, the next is what I found in user manual:
Remove paper from the printer to stop it printing. Turn it on, if not.
Set Remote Access Code, if not already, pressing Menu, 2, 5, 2. Enter three digits - 1, 2, 3 - for example and press OK.
Dial your fax number from a telephone or another fax machine using touch tone. When your machine answers, immediately enter your Remote Access Code (these 3 digits followed by *). If you hear one long beep, machine is saying that you still have faxes in memory. Then you hear two short beeps, that mean the machine waits your command. Use the dial pad to press 9 6 3.
If you hear one long beep, fax messages have been erased from the memory.
Nov 03, 2017 | Brother Office Equipment & Supplies
The Brother MCF7840W printer-fax-copier our business has will not stop sending a fax once it is in progress. We have tried the job cancel button and stop/exit red button. Do you have any suggestions on...
Hi there, It may sound like a dirty solution, but if you unplug the phone line or printer during a fax it will fail. You can then remove the paper you were faxing. I'm not sure why the cancel button is not working, but it may be fixed if you do a full power down and power up of the printer. Good luck!
Alex
Jun 02, 2011 | Brother MFC 7840W Printer
How to cancel a transmission
Pages 110 & 111 in users manual. During a direct transmission, press stop. For memory transmission, press job cancel, then select one of the 5 choices to cancel. 1.Transmit 2.Receive 3.Polling 4.Polling Reserve 5.Job Number Use the number keys to select the choice. Press Enter to cancel the selected job. To confirm deletion press1.
Oct 06, 2009 | Toshiba DP-85F Fax
What does NG mean for Status after sending a scanned item or faxed item?
I can advise you on the 'memory full' problem, mate.
If you get a MEMORY FULL message while scanning the first page of a fax, press Stop to cancel the scan. If you get a MEMORY FULL message while scanning in a subsequent page, you’ll have the option to press Start to transmit the pages scanned
so far, or to press Stop to cancel the operation. In this case, send the fax by the Manual Transmission.
Depending on your typical faxes, MEMORY FULL errors can occur frequently. If this happens, change the Memory Transmission setting back to OFF.
Thanks.
Jun 25, 2009 | Toshiba e-Studio237 Grayscale Copier
My HP printer PSC 1510 All-in-One no longer asks me to align my ink cartridges after a change of cartridges. Now, after a system recovery, it prints an alignment page every time I turn it on, whereas...
The only way to stop this is to press the cancel button, just as it tries to print the test page.
Various people have said the printer won't align (calibrate) successfully unless both ink cartridges are more than 50% full, and until it aligns successfully, it will continue to print the test page on start-up.
It is a total waste of ink and paper, so remember to hit the cancel button when you turn it on.
Apr 11, 2009 | HP PSC 1510 All-In-One InkJet Printer
How to clear Memory in Sharp UXP115
FIRST:1-PRESS START/MEMORY KEY IF YOU WANT TO TRANSMIT THE PAGES WHICH STORED UP TO THAT POINT IN MEMORY THE REMAINING PAGES WILL BE REJECTED FROM THE FEEDER.AFTER TANSMISSION THE MEMORY WILL BE CLEAREED.AND YOU CAN TRANSMIT THE REMAINING PAGES.YOU NEED ALSO TO TRANSMIT THE PAGE WHICH WAS BEING SCANNED WHEN THE MEMORY FILLED UP.
PRESS STOP IF YOU WANT TO CANCEL THE TRANSMISSION.
Feb 20, 2008 | Sharp UX-P115 Plain Paper Thermal transfer...
Waste absorber is full ip5000 and also ip200
Beware that doing the below may cause other issues with your printer - your waste absorber can overflow and spill ink into your printer causing more issues. It is best to replace this component via an authorised repair center or at least try and clean it out.
Give this a go, with the printer off, press and hold the resume/cancel/stop button, now press and hold the power button.
While holding the power button, release the resume/cancel/stop button.
While still holding the power button, press the resume/cancel/stop button 2 times and then release both buttons.
The power light should be on. Press the resume/cancel/stop button 4 times and then press the power button.
This should reset your Waste Absorber count, at least it does on my MP830 and also Pixma 4200.
Jan 25, 2008 | Canon PIXMA iP1500 InkJet Photo Printer
Keep printing test sheets
A lot of HP printers print a page to enable the print head alignment and calabration. This normally orcurs when a cartridge has been changed. If the alignment page fails then it will reprint alignment page until it can align.
So, you need to get that page it prints and place it on the glass and press scan, then it will complete alignment and be ready to rock.
See Here
Cheers
Jan 19, 2008 | HP PSC 1510 All-In-One InkJet Printer
Cancelling Incoming Faxes in Memory
see manual (can be download from homepage www.brother.com). If you are a victim of spam faxes you better buy a new mfc with a pc-fax-incoming-transmission function (e.g. mfc 440cn etc.) This will give you the opportunity to have a look at the faxes on the screen first and then to decide which one should be printed.
Jan 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Canon S 520 doesn`t print
Two flashes: Out of paper, paper jam or paper feed error
Replace the paper correctly and press the RESUME/CANCEL button.
If paper has jammed in the printer, clear the jam and press the RESUME/CANCEL
button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, replace the paper in the printer
Four flashes: Empty ink tank
One of the ink tanks is empty. Replace it.
Six flashes: No print head installed
Install a print head.
Seven flashes: Defective print head
Remove and reinstall the print head.
Also, ensure that the protective tape has been removed. If reinstalling the print head
does not resolve the problem, replace it with a new one.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight
flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL
button to cancel the error so you can continue printing. Before the waste ink tank
becomes completely full, contact a Canon service representative to have the waste ink
tank replaced. Canon recommends to call for service as soon as this error occurs. Once
the waste ink tank becomes completely full, printing will be no longer
possible.
Oct 19, 2007 | Canon S520 InkJet Photo Printer
Brother MFC-7440N Laser Printer Logo
77 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
