Question about Optics
Can't bring reflector telescope to focus.
I received a reflector telescope for Christmas, the clouds finally receded last night and I tried it out.
I can't bring the thing to focus though. The 'scope came with two eyepieces, a 10mm and 17mm "Super-Plössl". With either eyepiece in and, I presume, a star centred I only see the image of the secondary mirror struts highlighted against the primary.
I discovered that if I slide either eyepiece almost completely out of the drawtube (which is at full extension), I can get an image of the sky. I thought eyepieces sit completely in the drawtube though, not halfway or more out, grasped by the single fixing screw.
Is there something fundamentally wrong with the telescope? Does it just require collimation or somesuch?
  • 1 more comment
  • Chimney Jan 03, 2009
    Sorry for the lack of details. I'm sure I entered the make and model in a couple of fields in the problem submission form though :)
    It's a Newtonian, Orion Optics Europa 150 f/5 deluxe - here's the product page for it.
  • Chimney Jan 30, 2009
    The extension tube worked perfectly, thanks.
  • David Duffell
    David Duffell May 11, 2010
    is this a Newtonian or cassagrain. If you can give me some details of make etc. I'm sure I could help,
    Kind regards.....dave
  • 44 Answers
Orion UK has a very good reputation so I'm surprised you are having a problem. However, I see they are offering this with a Crayford focuser. Most Crayfords have a lower profile than traditional rack and pinion types and they may have failed to realize this could effect back focus. If the scope is new I'd talk to them. If not, find a 2" long by 2" diameter focuser extension tube.
If it does have a traditional rack and pinion focuser it may be missing the extension tube. Many of this type have a threaded on extension tube which is used for visual work and removed for use with a 35mm camera. The solution's the same.
Posted on Jan 07, 2009
How to use Twinstar Atroquest 8 Reflector telescope? I bought this telescope for my daughters and it did not bring any guide to learn hou to use it.
This is a reflector style telescope. Put the eyepiece with the largest number written on it into the focuser. Take it outside during the day time and practice focusing on a distant object.
If it is on an EQ mount read my EQ mount tip on my profile page. The scope will need to be polar aligned in order to use it properly if the mount is an equatorial.
Mar 20, 2011 | Optics
Looking at a clear bright sky at night and we can't see a thing - it is at if lowest eyepiece - got it from sears Dec. 29th - it is the Bushnell 3" reflector telescope w/talking guide and tripod
Can you focus during the day time on a distant object. If you can nothing is wrong with the scope. Objects in the night sky are tiny, smaller than the tip of your finger held at arms length.
Practice focusing during the day time, and read my TIPS on my profile page.
Jan 10, 2011 | Bushnell 3" Reflector Telescope w/Talking...
I just received as a gift, set it up and nowI am unable to see anything. the instruction manual is vague, only tells me how to set it up but not much else. thanks
The manuals DO NOT tell you how to find objects in the night sky, they are only assembly instructions. Wish you had not bought that telescope, this type would have been better for a beginner.
http://www.telescope.com/control/product/~category_id=classicdobs/~pcategory=dobsonians/~product_id=09804
Take the scope outside during the day time and put the eyepiece with the largest number written on it into the focuser. Practice focusing on a distant object. The moon should be your first target at night.
Locate an Astronomy club nearby and the members will help you learn the sky. All sky objects are smaller than the tip of your finger held at arm's length. The scope must be pointed directly at them to see anything.
Read my tips on my profile page.
Dec 16, 2010 | Bushnell 3" Reflector Telescope w/Talking...
I dont know how to use it
This is a simple reflector style telescope. Put the eyepiece with the largest number written on it into the telescope. Practice focusing on a distant object during the daytime.
Objects in the night sky are tiny and dim. They are smaller than the tip of your finger held at arm's length. The scope must be pointed DIRECTLY at them to see them.
Buy these two books, Turn Left at Orion, and Nightwatch. Local a local Astronomy club to help you with your telescope.
Read these:
http://www.texasastro.org/telescope.php
http://vimeo.com/channels/tas
Aug 14, 2010 | Bushnell 3" Reflector Telescope w/Talking...
Cant see any thing
Did you remove the lens cap? If the scope is like the picture in your question this is a REFLECTOR style telescope. It has a mirror in the bottom and a smaller secondary mirror under the focuser. The FOCUSER end is pointed UP. as in the picture above.
Can you focus on a distant object during the day time? Use the eyepiece with the largest number written on it and DO NOT USE the 2x barlow if you have one. Try focusing during the day time. If this works your telescope is OK. Then try the moon at night as your first target.
If you can see the moon up close all is OK.
Read my TIPS on my profile page.
Jun 18, 2010 | Celestron Advanced C10-NGT (600 x 254mm)...
I cant see anything when i look in the telescope
Is this a reflector or a refractor style telescope?
If it is a reflector with a mirror in the bottom the eyepiece and focuser looks like this when setup properly.
http://www.telescope.com/control/product/~product_id=08943
Notice they are on the end pointed UP. Do NOT use the 2 x barlow if you have one. Put the eyepiece with the largest number written on it into the focuser and practice focusing on a distant object during the day. The moon should be your first target at night.
Nov 20, 2009 | Optics
Can se through finderscope but nothing through eyepiece
Put the eyepiece with the largest number written on it into the focuser. During the daytime practice focusing on a distant object. The moon should be your first target at night.
If this is a reflector telescope, the FOCUSER end is pointed toward the sky. The mirror is on the bottom of the tube.
Aug 25, 2009 | Bushnell Optics
Please help. I need the user manual for c-star
That is a very simple reflector style telescope --- here is my suggestions-
1. Forget about the barlow--- since this scope has a very small aperture you will not be able to get much more than about 125 power-- if you try to use the barlow which DOUBLES or TRIPLES the power of your eyepieces the images you see will be degraded and it will be VERY hard to point the telescope and focus.
2. Put the eyepiece with the largest number (which is the lowest magnification) into the telescope and take it outside during the day and practice focusing on a distant object.
3. Take it out at night when the moon is up and LESS THAN 3/4 full-- the moon should be your first night target...... if all goes well try to find Saturn which is up in the sky right now, and appears as a slightly yellow "star".
4. The smaller telescope is the finder scope and mounts on top of the main telescope tube. Use this to point the main telescope------- but you must first line it up on a distant object so that the small telescope and the big tube are both pointed exactly alike.
5. Try to find a local astronomy club and attend one of their star parties.
6. Here is a manual for a telescope that is very similar to what you have except yours is on an Alt Az Mount while the one below is on an equatorial mount but many of the tube parts are the same--
http://www.meade.com/manuals/TelescopeManuals/Reflectors/Meade114STEQ-D.pdf
Mar 24, 2009 | Optics
Trying to identify older tasco telescope and put it together
There are only two types of telescopes --- REFRACTORS, and REFLECTORS-
The refractor has a lens on the front of the tube and you insert different eyepieces in the back-- the larger the number written on the eyepiece the LOWER the magnification-- (DO NOT USE THE 2x or 3x barlow which you may have!-- this creates too much power for this small telescope!-- put it away and never use it!)
A reflector has a main mirror on the bottom of the tube, and a small secondary mirror under the eyepiece hole (focuser end) - front end-- put the lowest power eyepiece into the focuser.
Now with either type telescope go out side during the day and practice focusing on a distant object-- turn the knob SLOWLY. At night the moon should be the first target you try.
If you received what appears to be a smaller telescope -- that is the finder scope-- attach it to the top of the tube on the main telescope. Again during the day line up the small finder scope with the main scope-- look at a distant telephone pole (the very top-- and center this in the main telescope. Without moving the main scope use the finder scopes "screws" to adjust the cross hairs so they are pointing exactly where the main scope is pointed. Now you can use the small finder scope to point the telescope in the exact direction--
The moon should be your first night time target.
Good luck--
Mar 17, 2009 | Tasco Astronomical 302675 Telescope
Cannot bring the moon into focus
leave your scope outside for a while so it can cool?
Jan 16, 2007 | Bushnell NorthStar 78-8890 (300 x 90mm)...
Optics Logo
244 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
