Question about Gigabyte K8N-SLI (GAK8NSLI) Motherboard
CMOS battery drains after one startup. Gigabyte GA-K8N-SLI
I upgraded the bios months ago and everything seemed OK. Later, I added a second DVD to my DVD burner. Wanted to read write to burn DVDs in one quick motion. I started to notice that it took a second push of the start button, then a third time before it work turn on the computer. Then it wouldn't start at all. I took out the CMOS battery and found it dead. I installed a new one. It worked fine for about a week when the symptoms started all over again. I installed a third battery and this time the battery was completely drained to a dead battery after one startup. Any help out there? gigabyte GA-K8N-sli amd 3800 x2 1.5g of memory evga e-gforce 7600gt sli video card 650 power supply
  • David Neris May 18, 2007
    I appreciate your help. I tried all of your suggestions and none helped. I ended up calling Newegg.com and they said the mobo was still under manufactor's warranty. I got a RMA and mailed the mobo to them. No word from Gigabyte yet. David
    Novelist:
    Scholar:
  • 104 Answers
OK lets see here! Make sure your CMOS jumper is set properly on the board(Set to Normal) or Did you configure your bios after flashing the bios(going into bios and Load Optimized Defaults!)? or I don't think it would be another device in the system, but you can try troubleshooting by starting up with only what you need to run the machine (Mobo, memory harddrive, keyboard and mouse) then one by one adding devices back! or Did you have problems like this b4 you flashed the bios! Try flashing the bios back to an older version! post back if anything new or if i'm way off! Good Luck regards, babb
Posted on May 03, 2007
How to reset BIOS on Gigabyte GA-H55M-UD2H. Here's my story. A long while ago, I set a password to my BIOS. But then almost 11 months later, trying to use it, I can't remember the password. Is...
check your motherboard manual fo CMOS reset jumper location on you motherboard, and follow the instructions on resetting to defaults. Keep in mind that any customisations implemented by you in bios will be lost, so you will need to do them again.
Hope that helps
Cheers from NZ
Jun 19, 2011 | Gigabyte Computers & Internet
How many graphics cards can you run on this motherboard ? also whats the maximum ram you can install on it ?
You may install 2 x PCI-Express X 16 slot, supports two PCI-Express interface Graphics cards with SLI mode and 4x1Gb Dual channel DDR400/ 333/ 266 -184pin RAMs onto your AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI Chipset 2000MT/s FSB Dual Channel DDR400 Socket 939 ATX motherboard.
Check out your motherboard's specifications through this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Apr 09, 2011 | AMD Gigabyte GA-K8N-SLI nVidia nForce4 SLI...
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
I own a GA-K8N-ProSLI Motherboard from Gigabyte. When I power it on, it boots normally till it gets past the POST. Afterwards, it just completely locks up and all hardware buttons cease to function (Power,...
Remove the hdd and try again. If now you can enter the BIOS and check that everything is correctly recognized and configured then the hdd has died, replace it. If it's the same then start by checking the power source, followed by the memory and the CPU. If all these are functioning then the problem is in the motherboard itself - unfixable, replace it.
May 18, 2010 | Gigabyte GA-K8N Pro-SLI Motherboard
Replace motherboard battery..... what after i mean the BIOS settings
when the CMOS battery is replaced the default Bios settings are retained, if u made any custom changes to Bios then u will need to do them again, things like boot menu processor speed settings ect. are you clear on this, 99% of time it changes nothing since most users don't even know what Bios is or how to alter it.
Apr 30, 2010 | Gigabyte K8N-SLI (GAK8NSLI) Motherboard
Can a Gigabyte K8N Pro SLI mobo support a PCIe 2.0 video card?
Hi Rachacha!
I have lait a few moths.
Off course, you can use the pcie 2.0 card on pcie 1.0-1.1 mobo, but the card effiency is only 90%, because the mobo have not enough power for the card.
Best regards
Kommy
Mar 11, 2009 | Gigabyte GA-K8N Pro-SLI Motherboard
No Sound on Gigabyte K8N Pro-SLI
Might be that the chip is bad, make sure that nothing is muted in your volume control also check that digital doesnt have a check on it. some times when digital has a check it wont let you hear anything.
Oct 19, 2008 | Gigabyte GA-K8N Pro-SLI Motherboard
Ga-k8ns memory problems
did you go into bios and check set up of ram speed etc
Jul 14, 2008 | Gigabyte GA-K8NS Motherboard
Gigabyte K8N-SLI (GAK8NSLI) Motherboard Logo
597 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
steyr1
pankaj rautela
pankaj rautela
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
