Question about Maytag Neptune MAH5500B Front Load Washer
Im wondering how to get the bearings out of the drum?
Im wondering
  • 179 Answers
You have to replace the back tub the bearing come built in the tub from the factory there is not any way just to replace just the bearings
Posted on Dec 30, 2008
Repair of drum bearing
Drum bearings can be a little tricky, depending on the your of machine. One thing I can tell you is you have to dismantle any machine to get to them.
Nov 07, 2014 | Washing Machines
My front loader washing machine is making a kind of squeaky noise when it spins. The washer is working..but wondering what it could be.
If the noise comes from the drum rather than the back of the machine it could be the drum bearings on their way out.
With the drum empty take hold of the top and bottom of the drum edge (from inside the drum). Gently try to lift and lower the drum, you may hear a slight knock - that's the bearings failing. Water enventually gets past the seal on the bearing and degergent in the water dissolves the grease in the bearing, causing it to fail.
Sep 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
RATTLING & DRUM NOT SPINNING EVENLY, ALTHOUGH CHANGED BEARINGS TW
Check the belt. it may be broken or, it may have slipped of the pulley or drive motor. if the belt is fine, replace the motor.
Jul 11, 2009 | Kenmore 98702 Stacked Washer/Dryer
How to remove the drum
before you take the drum out please do one simple check to see if the bearing have worn out.open the door and lift the silver drum inside up an down now if you ear a knocking noise or feel a knocking vibration then it definately the bearrings have gone.
Jul 06, 2009 | Washing Machines
When spining it makes very loud noise , like aeroplane when start
Hi.
It definately sounds like the drum bearings have failed.
It is a DIY job, but not easy, as it entails stripping the m/c down,
If it is under 5 years old, then it should be covered by a 5year warranty., you will just have to pay for the labour, certainly the cheapest option.
Nov 23, 2008 | Kenmore Elite 45986 Front Load Washer
Hotpoint washing machine
hello im sorry to say that you machine is in serious condition and with out a bearing transplant the prognosis is fatal.
The Problems what it could be
1 drum bearing. should not be tackled by the non technical types because you do need to know what your doing.. depending on what model it is i can give you some instructions.
2. Broken spider on internal drum, (the one that spins) can be done but better tackled by an engineer
3. Something caught in the drum most common one is bra wire.
To check to see if it is the drum bearing then open the door and hold the drum (steel bit lol) at the 12 oclock and 6 o clock and se if there is any movement if so its either problem 1 or 2
if you need any help dont be shy to ask
im here free of charge...
Dec 24, 2007 | Washing Machines
Washer wont spin belt came off put it back and tested on a spin but then it started making weird noises so we stopped it. turned drum manually but then drum jammed going one way but not the other
two possible causes. first - foreign object stuck between tub and drum. take heater out and you can peer into the gap between tub and drum second - bearings collapsed and im afraid this is the most likely cause. if memory serves me right, hotpoint supply a replacement tub and drum assembly at vast cost. lots of problems with bearings on the wma series
May 23, 2007 | Hotpoint WMA50 Front Load Washer
Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Apr 26, 2007 | Zanussi F1045W Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
69 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
