Question about Logitech VX Revolution 931690-0403 Mouse
Vx problem:movement I bought this mouse,the vx revolution and it worked fine for a couple of hours.Then,suddenly it stopped responding and the cursor doesn't move...The mouse appears to be on and everything looks fine but it's not working and it drives me mad 'cause I bought it for 50 euros!
    President:
  • 8,637 Answers
First try this
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
If that doesn't do it theen try this.
Normal 0 Disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Posted on Jan 27, 2009
MY LOGITECH MX REVOLUTION MOUSE NOT RESPOND
There are a number of reasons why your mouse isn't reponding:
  1. Check that the batteries are full
  2. Check that the mouse is synchronised with the adapter
  3. Check you have the correct drivers installed.
If none of these things help you, then if your mouse is still under warranty, I'd ask for another one.
Good luck! John
Mar 13, 2011 | Logitech VX Revolution 931690-0403 Mouse
HI vx revolution mouse repair
no sorry, once the little pins and rollers inside have broken their isn't any way. I'm really sorry.
Dec 25, 2009 | Logitech VX Revolution 931690-0403 Mouse
My VX revolution is missing too much left clicks. Sometimes I need to click 5 times to get 1 click. All the others buttons are working fine. How I can fix this? thks
Seems that the left mouse button needs to be replaced. If you have an old mouse, you can use it as a source of a spare mouse button, & replace the defective button on your VX Revolution.
However, you need to make sure that:
1. The replacement button is identical to the defective one.
2. You have enough skills to solder/desolder electronic components.
Oct 25, 2009 | Logitech Cordless Click! Mouse
Wrong Receiver for Logitech Vx Revolution Mouse
logitech has connection software on their site you need to run
Jul 07, 2009 | Logitech VX Revolution 931690-0403 Mouse
Unresponsive left mouse click
I have that issue too. At the beginning I tought it was a connectivity problem but it does it even with the receiver side by side. Latelly it is working perfectly.
Jun 10, 2009 | Logitech VX Revolution 931690-0403 Mouse
Mouse wheel is inverted
if you are using Windows go into conrol panel and click on mouse. it will show you the options to change the buttons..
pls rate this solution
Mar 01, 2009 | Logitech Wireless VX Revolution Laser ...
Regarding the VX revolution mouse
Hi. Partial / Potential solution:
I think there are screws holding the mouse together, and that they are located under the 'plastic' pads on the bottom of the mouse. On mine, the pad directly behind where the battery goes (towards the 'tail' of the mouse / palm of hand) popped off easily to reveal a screw that came out easily enough. The other pads are stickier, tho, so for me it's not worth trying to mess with them now. If it gets worse, I'll take them off and see what's to see. If yours is pretty bad, it might be worth it. Cheers...
Jan 01, 2009 | Logitech Wireless VX Revolution Laser ...
Mouse doesn't follow
I would venture that for some reason, the LED light at the bottom needs that much space to bounce back the signal for the LDR (light dependent resistor) to read properly. This could be due to a slight misalignment, dust in the bottom optics, weak battery (for wireless). A temporary workaround (which for some works as good enough solution) is to add a smooth spacer atop the rubber feet. Personally, I use a paper puncher to cut little circles on a slightly thick automotive sticker. The circles are then peeled of from the protective paper backing and attached to the existing/original rubber feet. This raises the bottom height which do improve light bounce and therefore mouse action.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 18, 2008 | Logitech VX Revolution 931690-0403 Mouse
Logitech VX Revolution 931690-0403 Mouse Logo
343 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
