Question about Refrigerators
I have a GE refrigerator that has been sitting idle for a couple of years that was working previously. The compressor is running but fan is not circulating air not getting cold at all. What is the problem and possible solution?
  • 700 Answers
What there could be is that the refrigerant has leaked out of the unit and not cooling the coils to provide the fan with the proper coil temperature to turn on. take and put your hand on the lines near the compressor. one should be cold and the other hot. if they are about the same the yu have a leak. Don't forget to rate the solutions for you questioins after you get yur answer. Thanks for using FixYa.
Posted on Jan 01, 2009
NO POWER TO COMPRESSOR
All compressors have a 1) Bi-metal t-stat and Most have
2) Start-Capacitor assist with 3) Plug-in Start Relay.
 All 3 parts are available at Most Appliance Repair stores and are not that expensive. It is usually 1 of the 3 that has failed.
If your Condenser Fan is Running it is one of the three components or a burnt off wire ... Be Safe.
Good Luck.
Oct 11, 2007 | GE PSI23MGN Side by Side Refrigerator
I just moved the fridge to a new house and now the fridge and freezer won't get cold. It had been sitting in storage for over about a year, but worked perfectly before that.
Its possible that during storage a few things may have happened. There is a small fan under the back that keeps the compressor cool while running. Its possible that during moving something shifted or bent the fan area and its not running. Could also be a small critter built a nest in that same area stopping the fan from running. Without that fan--- the compressor will run a very short time and then cycle itself off on the heat safety when it gets too hot. It will keep short cycling off the heat overload until the fan runs again. It will not run long enough to get to proper temp. Just guessing but check this first.
Jun 18, 2015 | GE Profile PFSS6PKX Bottom Freezer French...
Our GE side-by-side refrigerator (model GS225) is not cooling. Freezer is at 55 degrees and the refrigerator is at 70 degrees. The fan condensor in the back was dirty so we cleaned it. Could that be the...
Check the compressor relay. All fans should be running when the compressor is except during post dwell. In post dwell the compressor and fan con on but the inside ones do not come on for a specified time. SEE ADC how it works.
You can use the diagnostics found in this GSS SERVICE MANUAL
Aug 02, 2010 | GE Refrigerators
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Refrigerator was not cold, now freezer is not working either
You hear a fan running - but do you hear the compressor motor running too ? Common problems are defrost timers and refrigerator being stuck into defrost - or control board problems or faulty thermostats - Those defrost timers tend to go bad more frequently on newer refrigerators compared to the older refrigerators !
Aug 17, 2009 | GE Refrigerators
GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Aug 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor runs but circulating fan does not.
Sometimes when a refrigerator is closed up for a while the moisture collects on the fan motor. I recommend that you not run the refrigerator like this until you can remove the rear panel and try to get the fan spinning again . Try turning it and allow the rust to loosen up. This will get the fan going providing the fan has not burned out due to not spinning. Sometimes other things can cause this, but for now try this and if it works please rate me. Let me know if I can help you get your refrigerator going, that's what I am here for. Thanks, Sea Breeze
Jul 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer cold /refrigator warm . we have a side by side unit a couple of years old the freezer seems to work fine but the refrigator is warm .It don,t seem to make any funny noises and the back is clean
When the compressor is running, if the fan by the compressor and the fan inside the freezer are both running, and there is no frost on the back wall of the freezer (if there was frost would indicate a defrost issue) then check the air dampener. It is located at the very top left back side of the fresh food section. If it is not opening up, no air will flow from the freezer compartment (where all the cooling takes place) into the refrigerator section.
Jul 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Food and water freezes but ice cream is soft
Check the door gasket seal.
Open the door for a few seconds and then close.
Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
Mar 30, 2009 | Refrigerators
Refrigerators Logo
46 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
