Question about Toshiba (225EXTR5)
Screen problem i have a toshiba laptop, the kids dropped it and the screen is broken now. i connected it to a screen and it was working good but i did something wrong with the "adjust screen resolution" i was trying to fit it on a big screen and then i lost the picture i tried to fix it using another screen but it didnt work and i still dont know how to get into my laptop because i cant change the settings again. please tell me what i have to do because i need to get pictures and files from the laptop. thank you.
    Scholar:
  • 149 Answers
Boot up laptop...after bios screen ....press F8 (to get safe mode options)...choose safe mode.....when windows has booted ....go to control panel....display options...settings.....change the display to 800 by 600 and save and reboot into normal mode
Posted on Jan 07, 2009
Samsung 5c512 will not display
Ok, the screen is out but... If the laptop has VGA connector you can connect an external monitor and if the laptop recognizes it maybe you can know if the motherboard is working. Good luck.
Apr 04, 2014 | Samsung Rc512 Intel Motherboard...
Screen wont work Toshiba Satellite L555
It is sure that the screen/LCD panel is damaged and there is no option but to replace the whole unit.
If you are lucky check out on service shops for a scrapped L555 due to a mother board failure which would be reasonable.
Dec 20, 2011 | Toshiba Satellite L555D-S7005 Notebook
My toshiba p300 equium accidentally drop by my niece and the lcd was broken, and im tying to use the hdmi port to my lcd t.v and still does not work, what else should i do, pls help me. tnx
replace your lcd panel from your laptop then you can turn on the external lcd tv screen
Its the only thing you can do really
Buy a secondhand unit same model and transplant the lcd panel
Apr 11, 2010 | Toshiba Satellite Pro P300 Notebook
Laptop screen is damaged
you can continue using your external display or purchase a new screen and install it . check out this site for good step by step instructions, just find your model. Good luck to ya
Jun 11, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Screen black & with no power
hi there,
you can follow this instruction and try to your laptop to resolved the problem.
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with Toshiba Satellite M35X and Toshiba Satellite A70/A75 notebooks. If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it’s still under warranty, it would be fixed at no charge to you.
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. Toshiba Satellite M35X and Toshiba Satellite A70/A75 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system board with a magnifying glass. In most cases you get the power problem because of a bad connection between the DC jack and the system board, you’ll see a crack between the DC jack connector and the system board.
Here is an example of Toshiba Satellite M35X power jack. The crack occurs between the DC jack pin and the system board.
satellite-m35x-crack.jpg satellite-m35x-contact.jpg In some cases the connection is good, but the DC jack is bad itself. You can find a new DC jack for Toshiba Satellite M35X and Toshiba Satellite A70/A75 laptops here. Search for DC jack M35X or DC jack A75.
How to resolder laptop power jack yourself.
UPDATE:
Sometimes, after you replace the jack, you can see that the system board doesn’t get power at all. The battery will not charge and the power LED will not light when you plug in the AC adapter. So, here’s a possible explanation.
When a connection between the positive pin and the motherboard breaks (cracks), the power jack gets loose. You can feel it when you plug in the adapter plug. A loose power jack can damage the trace inside the hole in the system board. Take a look at the picture.
power-jack.gif As you see, the positive pin goes through the hole in the system board and you solder it on the top side. Right? What if the trace between the top side and the bottom side is broken somewhere inside the hole? I’ve seen it before a few times. In this case everything looks nice and clean on the top side. When you plug in the AC adapter, you get normal voltage readings between “+” and “-“ pins on the top side, but the power DOESN’T go to the motherboard at all, because there is no connection between the top and bottom sides. Test with a multimeter if there is a connection between the top and the bottom.
If the trace inside the hole is broken you still can fix it. You can run a wire to connect the top and the bottom sides. Be careful not to short something on the board.
Update:
Here’s another solution to fix the power jack problem, it shows how to relocate the power jack outside the laptop base. Check it out here: Toshiba Satellite A75 failed power jack workaround.
When you repair a loose power jack, it’s a good idea to check the jack on both sides of the motherboard. When you remove the top cover from a Toshiba Satellite A70/A75 laptop you can see only points where the jack is soldered to the motherboard as it shown on the second picture in this post, but you cannot see the jack itself as it shown on the first picture.
Removing the motherboard from Satellite A70/A75 laptop is a good idea because the jack itself might has a broken “+” pin, as it shown on the picture below. If the “+” broke off the base, you’ll have to replace the jack.
Feb 15, 2009 | Toshiba Satellite A75-S229 Notebook
No Display, no audio, no power up sounds.
Sounds like a hardware failure because your not even reaching post. which means that its not software. i would take out the ram and hard drive. and then putting them back in. if that didn't do anything than I'm going to say you've probably got a dead mother board.
Aug 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Screen only showing vertical lines after being dropped
The damage could be either in the LCD screen or the connection cable. Open the screen assembly and check the connection cable first.
In case it doesn't work you can find replacement LCD screens here.
www.piezas.biz
Jul 02, 2008 | Toshiba Satellite M55-S135 Notebook
Computers & Internet Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
