Question about GE Advantium SCA1001SS Convection / Microwave Oven
Is the Advantium Mod: SCA1000HCC03 the same as the SCA1001SS?
The cavity lamp in my Advantium Mod: SCA1000HCC03 has just gone out after only four months of use. Is there any test to be done to assure it is only the lamp that's bad? Additionaly,has anyone a guide to replacing this lamp??? Thanks, JD
I have model SCA1001HSS02 and the cavity light burned out recently. Manual doesn't even mention a cavity light. Searched on GE website "Knowledge Database" and found nothing but recommending contacting GE service center for repair. Come on! It's a light bulb! Found this site and I was able to replace the bulb in 10 minutes without having to remove from the wall. Thanks justmeagain. Follow directions as justmeagain described. I'll give a little more detail on how to do it. 1) Remove front grill(two screws) that runs horizontally across top of unit. This grill is black and brushed nickel. 2) Once grill is removed, remove vertical,black plastic guard(two screws)that covers electronic componets. This cover has square holes and is located center right. 3) Once plastic cover is removed, remove sheet metal cover that is ~2" high and 4" long at the center. There are no fastners holding this in place. 4)Remove 1 sheet metal screw holding down larger horizontal sheet metal cover just to right of black plastic housing on left side. 5) You're now able to lift larger horizontal sheet metal to access light bulb holder. The bulb is located under a metal hood that is in the same general location as screw that was removed on left. Just squeeze metal hood and remove bulb holder. Pull out burnt out bulb. 6) Caution: Don't touch new bulb with bare fingers. Use paper towel or something to insert new bulb. 7) Reassemble and your done. Congrats, you just saved yourself $185.
Posted on Oct 04, 2007
Remove the vent grill AFTER unplugging the unit. There will be a metal cover in the middle of the micro behind the Vent grill. Under the metal cover you will find the light bulb on the left side under the plate with another metal clip with 2 white wires wrapped in a heat protected sheath. The light shield pops out by gently squeezing it and lifting up.
Posted on May 16, 2007
  • GE Master
  • 9,149 Answers
They are indeed the same bulb, a 10W halogen. Care must be taken not to touch the lamp, as the oils from the skin will shorten its life. In many recent models, the oven must be removed from the wall (a two-person job due to safety concerns) and the cover must be removed. The manufacturers consider this a "technician-only" type job to lessen their liability. You can find helpful exploded view diagrams of both ovens and order the bulbs here: http://tinyurl.com/gv383
Posted on May 03, 2007
  • William Miller
    William Miller May 03, 2007
    Slamming the door too hard can possibly shake the heat filament and lessen its life.
    When you get to the old bulb, you can see that the filament is broken.
Fuse location
Behine or part of control pannel.
Sep 07, 2014 | GE Advantium SCA1001SS Convection /...
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium sca2000bbb03 does dont heat everything works right but wont heat.
I had this same problem with no heat. I called the GE rep out and he replaced the magnetron thinking that was the problem and put back together and had the same problem. I just happened to press in on the door while he was studying his diagnostics and it started heating. He then replaced the door switch and all was well.
Aug 22, 2009 | GE Advantium SCA1001SS Convection /...
Preheated oven with glass dish...tried to bake..now no power
they have a fuse that blows if the cavity gets to hot looks like a small thermostat
Jun 30, 2009 | GE Advantium SCA1001SS Convection /...
GE Advantium Microwave section doesn't work.
The primary interlock switch on my Advantium has failed twice. The replacement part is available at: appliancepartspros.com part no. for my Advantium was AP2622452 and it cost $11.74 + $6.95 shipping.
For what it's worth, my nylon connector and wire covering were also scorched a bit but the last primary interlock switch lasted me for over a year.
Please note that I am not an expert at repairing appliances and that I assume no responsibility or liability for any attempt you may make to repair your own appliance.
May 30, 2009 | GE Advantium SCA2000B Microwave Oven
Blinking display of advantium m/w oven
by unplugging the m/w for a few minutes and then replugging the problem is gone.
May 29, 2009 | GE Advantium SCA1001SS Convection /...
The door handle on my GE Profile ADvantium 120 Microwave is broke
appliancepartspros.com. part number AP3187809 $56.40 plus shipping
Apr 27, 2009 | GE Advantium SCA1001SS Convection /...
I want to replace the door
I do not think you can change the door. I can be wrong though. call ge at the number on this link.
http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SPECPAGE&SKU=SCA2001KSS&SITEID=GEA&TABID=3
Good Luck and Please Rate
Jan 07, 2009 | GE Advantium SCA1001SS Convection /...
GE Advantium SCA1001SS Convection / Microwave Oven Logo
204 people viewed this question
Top GE Microwave Ovens Experts
vince
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
