Question about Coby MP-C7085 MP3 Player
My mp3 player only works when it is pluged in to the charger.
Have you let the battery charge? You are supposed to charge it at least four hours the first time, or until it is full. You just need to leave it connected to the computer for it to charge.
Posted on Dec 31, 2008
2 Suggested Answers
  • 8596 Answers
SOURCE: my mp3 player not working
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 27, 2008
Is there an ac charger for the sansa clip+
You can charge the MP3 player with the USB cable that came with your player by pluging it into the USB port of your computer OR into a 5 volt USB mains adapter.
Aug 20, 2011 | SanDisk Sansa Clip MP3 Player
Hi I got this as a hand me down daughter loves it,,,but,,no does it charge...we did not get a charger??!!Batteries??? Thanks BL
The player has a built in rechargeable battery that can charge by pluging it into a usb port on your computer or into a usb wall charger. if you have a mac i should warn you it will only let you charge nothing else.
Mar 02, 2010 | Mattel Barbie Girls MP3 Player
My ipod shuffle (1st gen) is not working!
did u try pluging it in 2 a wall charger
Mar 14, 2009 | Apple iPod shuffle MP3 Player
Ipod mini doesn't turn on
If you mean on the charger as in pluged into your computer this will not charge a completly dead ipod because it tries to run i-tunes at the same time. So when it gets enough power to start to turn on then i-tunes draws more that it has , you need to plug it into a wall charger for a while if this does not work the batteries are bad and need to be reolaces.
Mar 05, 2009 | Apple iPod mini M9160LL/A MP3 Player
704wifi charging problems
Return It.
Did the Other Charger actually work?
Oct 10, 2008 | Archos 704 WiFi Digital Media Player
I need a new charger for innovage mp3 player
if its like most of the MP3 player
has, just plugging it in to the computer via the data cable will charge it. just leave it pluged in when not in use.
and when on the computer, it will stop chargeing when the battery is full,
May 01, 2008 | Audio Players & Recorders
Will only turn on when pluged into A/C charger
happened to me. and i turned the battery button on and off again. but after a while i did it and it worked. check the LOCK button too.
Feb 24, 2008 | Toshiba gigabeat S MP3 Player
Not charging with AC charger
DID u try a different AC charger?
Nov 30, 2007 | Teac MP-8000 20 GB MP3 Player
Coby MP-C7085 MP3 Player Logo
102 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
