Question about Mitsubishi WS-65807 65" Rear Projection Television
Relocating tv I have a Mitsubishi WS65807 Projection TV that i want to move to a lower level in my house.. With th size and weight, it is impossible to move down 10 stairs. does this unit come apart to make it easier to move?
    Novelist:
  • 192 Answers
Yes, this set does come apart for moving. Remove the lower screw from each side of the TV back. On both sides, pull off the two plastic caps and remove the two exposed screw. Lift the cabinet top straight up until the guide pins clear the holes in the bottom cabinet. Be careful and don't drop anything.
Posted on May 03, 2007
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
I Need part number 930B868001 for my model WS65807 tv. Where can I get it????
That board has been discontinued for several years now. Ebay may be the only place you may still find the Signal board your needing.
Jul 11, 2011 | Mitsubishi WS-65807 65" Rear Projection...
I need convergence chip #'s for a misubishi WS65807 tv
Mitsubishi's part# 267P150010
Generic part# STK392-570
You will need two of them.
Apr 14, 2011 | Mitsubishi WS-65807 65" Rear Projection...
The lamp went out in my TV. I replaced the lamp and it worked fine. I moved the TV and when I went to turn it on it wouldn't stay on. It will come on for about 10 seconds and then shut back off. The red...
Recheck all the projection lamp conections again.Still getting,the same result.Replace the projection lamp again,some how the move,it got the projection lamp shorted.
Oct 03, 2010 | Mitsubishi WD-60735 Projection Television
Reflection and glare on a 55'' Mitsubshi projection TV
I have the same problem with my Mitsubishi and the only solution I have come up with is slightly moving the TV's angle so the reflection is not as bad and closing drapes or curtains. Also turn off lamps. This is a poor design but Mitsubishi is not the only TV that has this type of problem. It is something I have become accustomed to and do not notice it as bad since I have moved the TV angle.
Jul 31, 2009 | Televison & Video
Mitsubishi WS65807
The Color Signal on this Model Series travels across three boards before being sent to the CRTs. The 3DYC Board, Signal Board and the Terminal Board. Most likely, the 3DYC Board or the Signal Board is causing the problem. I have had intermittent solder connections on the 3DYC Board to cause no color problems. This Board plugs in and is located on the left front of the Signal Board as you look from the rear of the chassis. If you feel you are not up to the task to work on the set, call a Mitsubishi professional. To find one, call Mitsubishi at 1800-332-2119.
I hope this helps,
Skyassoc
Jul 24, 2009 | Mitsubishi WS-65807 65" Rear Projection...
Estimated Weight
Direct quote from 2001 Mitsubishi Product Catalog Specs. Gold Series
VS-70707
Weight (approx. lbs.) 365
Jul 19, 2009 | Mitsubishi VS-70707 70" Rear Projection...
How to disassemble a VS-70705 for transport
I found the problem. Mitsubishi put 2 strips of what looks like rubber caulking inside, presumably to keep the TV from rattling or something. Peel them off from the inside and the top comes off just fine. Both pieces are still very heavy, so its at least a 2 man job moving either piece. Most of the weight seems to be the LDF more than the TV though.
May 25, 2008 | Mitsubishi VS-70707 70" Rear Projection...
Needing a new remote
if you are wanting the original remote you can visit:
http://www.remotes.com/store/mitsubishi/ws65807.html
if you are wanting to control more than just the tv such as an entertainment center i would go to a technology store such as circuit city and purchase a harmony remote
Feb 16, 2008 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
316 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
