Question about SanDisk 4GB microSD High Capacity Memory Card
Pc not recognizing sandisk micro sd
Have new 4gb sandisk micro sd w/sd and usb adapter. my pc does not recognize it! my pc reads all my other micro cards/flash
The Card Reader you are using is probably not compatible with SDHC Memory Cards (High Capacity SD). You may need to get an SCHC compatible reader or check the website for your product to see if the is a driver update. You can get a new reader for about $20 bones if needed. I had the same issue.
Posted on Jan 05, 2009
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
Win 7 does not recognize pen drive
From the SanDisk website it says Win2000 and WinXP certified. It says nothing about Win7. try it in a different pc with Xp and see if it works. If it does then it is not compatible with Win7
Apr 04, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
SanDisk 4GB MicroSD HC Memory Card is not recognized by my Sansa
sd utility.exe u download from google it wil dolve u r problem.......
Sep 29, 2009 | SanDisk 4GB microSD High Capacity Memory...
My PC will not recognize my 2GB Micro SD Card
Does the PC recognize the adapter when you place onto the USB port? If not, try another USB port. It should atleast say it has detected hardware, see if it's finding and installing the drivers correctly.
If it's not the adapter, could you reformat the microsd card? Perhaps, it is corrupted? Is this SDHC or SD (what capacity). Older Blackberries do not support SDHC (I believe this is 4gb or above), perhaps this has something to do with it.
I hope this helps,
Bill
Sep 04, 2009 | SanDisk 2GB microSD Memory Card
Sandisk 4gb micro SD with adapter is "unreadable"
Certain cameras will not recognize an SD card because it is SDHC. The format was created after the camera. Camera vendors do issue firmeware updates.
Hope it helps.
Aug 27, 2009 | SanDisk 4GB Secure Digital High Capacity...
SanDisk 4GB thumb drive not recognized by my computer
Try any other computer but not open drive only see if they can read it. Also change USB port, sometimes some ports dont accept devices. Also check for latest antivirus software last such case viruses dont let me read any of my USB drives. If driver works to oter PC then you have virus.
Aug 11, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Micro sdhc card reader will not recognize 8gig card
You problem is most likely to be the fact that your micro chip is a HC chip. HC chips have a new program that is not backwards compatible to regular sd host ports. This is a simple fix, however. If you don't trust downloading programs for it on the internet, just go to target or walmart and get a USB SD card reader, and a SD adapter if you don't already have one. The usb adapter should only be like $10 at most.
Jun 07, 2009 | SanDisk 4GB microSD High Capacity Memory...
Micro sd card not working
I'm having the same problem with a Transcend 4GB microSDHC card / microSD adapter. I have also found it probably has something to do with the card reader...either the card reader is an SD card reader trying to read an SDHC card OR the card reader is not able to read high-gigabyte SD cards (over 1 GB in some cases).
Jan 23, 2009 | SanDisk 4GB microSD High Capacity Memory...
4gb sd card
some (like my iRocks IR-5300 adapter) won't recognize cards over 2GB. Check the spec on the pocket PC.
Nov 29, 2008 | SanDisk 2GB microSD Memory Card
SanDisk 4GB microSD High Capacity Memory Card Logo
751 people viewed this question
Top SanDisk Electronics - Others Experts
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
