Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
System restore disable
I can not open the system resroe icon , my pc run with win xp pro
please help
  • dmantek May 11, 2010
    Do you get error when trying to open it? Are you trying to access it through start/programs/accessories/system tools?
    Have you tried opening system restore through msconfig?
    Problem Solver:
  • 6 Answers
1. Right-click on 'My Computer' 2. Click 'Properties' 3. Select 'System Restore' tab (top left of dialog box) Voila :)
Posted on Dec 30, 2008
    President:
  • 1,179 Answers
Open your system properties. Check to make sure the system restore feature is enabled. I had to do this on my old computer as you have to tell the restore feature how much hdd space to dedicate to restore functions. Hope this helps & please remember to rate my answer. Thanks.
This is what happens when you turn the computer on . Nothing else can someone help to get it back to how it should be...
2 Solutions
Boot to Safe Mode, by pressing F8 during boot. Then try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Remove all USB attached devices like drives.
You may need to roll back system with System Restore. Under Safe Mode (press F8 during boot and choose Safe Mode).
Win 7 - Start > Search type System Restore.
XP - Is Start > All Programs > Accessories > System Restore. Now choose a date prior to problem. You may have to try a few dates.
Uninstall last program(s) that was installed, again in safe mode.
Nov 12, 2012 | Computers & Internet
When I try to open my program I receive the following message, "Your registry settings for this application were not copied correctly. To correct these settings, run Setup again for this application...
Please restore your system , In previous state
Please follow the bellow links,
System Restore WIN XP systemrestore2 Backing up-System Protection and System Restore in Windows 7 Windows XP System Restore Is Easy to Use Use System Restore to Undo Changes if Problems Occur Using System Restore in XP - How-To GeekHope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 25, 2011 | Microsoft Streets and Trips 2008 for PC
GET RID OF SOME TASKBAR ICONS, NOT JUST HIDE.
You can type at the RUN MENU : msconfig
You will get system configuration utility open
select: SERVICES and the select HIDE ALL MICROSOFT SERVICES.
un tick the box of the program you don't want.
also
on STARTUP MENU untick the box of the program you don't want .
ok
you can use malwarebyte free for 60 days to remove unwanted things in the registry
hope this tip will help you
regards
uttam
Dec 21, 2009 | Microsoft Windows XP Professional for PC
Xp pro sp2 desktop icons have become mere links without any program / application skins" . Have been opening program from start menu. pls help!!!!
It sounds like you have a virus infecting the computer.
I recommend that you attempt to restore the system to an earlier date before the problems occurred.
If you click on the start menu and click on run, type rstrui.exe and hit the enter key.
System restore will pop up, choose a date that your comfortable with and see if you can restore the system.
If you experience any difficulty please post back.
Good luck.
Nov 11, 2009 | Microsoft Windows XP Professional With...
Lost system restore functionality after installing second xp pro
My computer properties system restore check if system restore is turned off.
If yes turn on all drives and restart.
If system restore is on then you need to create a new admin account and check system restore settings.
Also you need to have 6gb of free space in windows partition
Enjoy this will solve
Feb 08, 2009 | Microsoft Windows XP Professional
Removing partial install of 2nd os
You should be able to do a SYSTEM RESTORE to a point before the XP Pro installation.
Start the machine and start tapping the F8 key until the boot menu is displayed. Use the arrow keys to highlight SAFE MODE and press enter. If you are given a menu to choose which Windows to boot into, choose the Home edition. Windows will load with the minimum drivers. Your screen display will be 640 X 480 and the icons will be large. You will eventually see a window advising you that you are in safe mode, click OK or NO. Click NO. That should open The System Restore function. Choose to restore the system to an earlier date. A calendar with be displayed. The BOLD dates are the ones that you can restore to. Choose a date that was before the date you tried to install XP Pro. Follow the prompts and the restore process will run and reboot your computer. Following the reboot, the installation will complete and Windows will open.
If you have installed a service packs or updates after the restore date you will need to install them again.
Good Luck! and please let me know how this works out for you.
Jan 16, 2009 | Computers & Internet
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
    • Load Startup Items
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
NT4 sees XP Pro in network neighborhood, but access denied
If you arent too worried about security since it is at home, enable the guest account on the windows XP machine, also disable the firewall on the XP machine ( it is on by default )
let me know
Oct 29, 2008 | IBM NetVista PC Desktop
DVD Drive auto ejects on stratup of system & Remains open
did this happen after you have updated your win xp to sp3? try to do a system restore. go to all programs>accessories>system tools>system restore> go back to the date before the sp3 was installed. try also updating the driver for your optical drive
Jun 12, 2008 | BenQ DQ60 DVD RW Dual Layer Burner
I am getting an error " registry editor disabled by administrator"
your win XP 2 infected with virus. Maybe rontokbro@mm. to restore back the regedit. download this file
save to your desktop then
Right-click the UnHookExec.inf file and click install. (This is a small file. It does not display any notice or boxes when you run it).
Hope it's work for you.
Feb 19, 2008 | Microsoft Windows XP Professional With...
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
81 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
