Question about Coleman Powermate Powermate 5000W Generator
Coleman Powermate Progen 5000, the 240 locking 4 plug, how to wir
I bought an L1420-P plug (what it calls for) for the 240 output socket on my Coleman 5000W generator. I want to build an extention cable, any idea how to wire it. The new plug is marked as follows, G=green,X, W, and Y reading counterclockwise from green. I need the 240V to power a 240V 2000W heater.
    President:
  • Coleman Master
  • 1,388 Answers
The L1420p is a common plug used for most all generators having 20amp outlet with ground. The markings on the plug are as follows; x,y, are hot connections 115v each; w connection is neutral; g is ground. You will need a four conductor cable to connect all the wires. In some cases, there is no need to connect the ground wire because on the generator, the ground is the frame. Check your manual for the proper method of attaching a ground to your generator. So unless you are grounding the frame to a ground rod or other method, the ground wire on the plug just goes to frame. If the heater is used on a jobsite, check local codes or OSHA requirements. You could also just ground the heater like many appliances in the home where there is an extra ground wire from the frame of the appliance to ground. Good Luck
Posted on Dec 31, 2008
After a good nights sleep it hit me like a rock. 25 years out of electronic school came back to me BUT, someone responded with the cure too.
I really think everyone for the help. I will continue to monitor the sight. May be I can help someone some time.
The generator hasn't, been used in a while and is not cranking. Gas is getting to the spark plug and the plug is clean. What could be the issue?
Coleman starter not cranking Power Generators Questions ...
www.fixya.com > Forum > Tags > starter not cranking > Power Generators
Coleman power generators starter not cranking related questions and answers. Ask your ... Ad. Question about Powermate Powermate 5000W Generator.
Powermate coleman 5000 gen. with subaru engine ... - faqqq
www.faqqq.com/.../powermate-coleman-5000-gen-with-subaru-engine-col...
Question Product: Coleman Powermate Powermate 5000W Generator Question ... it would crank for a second, then i open the choke, it would die, would not stay ...
Fixing Electrical Problems in Coleman Powermate Generators
www.alpharubicon.com/altenergy/colemanpenwu.htm
*Fixing Electrical Problems in Coleman Powermate Generators* By: Penwu 29 April 2006. All of Coleman's portable Powermate line of generators use brushes ...
Coleman 5000 watt generator cold start - YouTube
? 4:35
https://www.youtube.com/watch?v=pcT989l0rm0
Nov 3, 2011 - Uploaded by stevenpturcheck
well im starting to cycle though my equipment before winter so more cold ... How To Change Oil On Coleman Powermate Generator / Yearly ...
Jan 21, 2016 | Coleman Powermate Powermate 5000W...
Need a wiring diagram/schematic for the power output end/recepticals for the coleman powermate 5000 model pc0545305.01 generator
Couldn't get you a wiring diagram but the contact info should get you to someone who can. The other links will get the manual and parts breakdowns.
http://www.powermate.com/contact.php
http://www.powermate.com/pdfs/2007/11/12/manual_pc0105000.pdf
http://www.powermate.com/pdfs/2007/11/12/parts_pc0105000.pdf
Oct 01, 2012 | Coleman Powermate Powermate 5000W...
I have a coleman powermate PM0495503, and it has four wires coming from the stator. 2 blacks and 2 whites. When I ohm them out, one white ohms through to one black and the other white ohms through to the...
On a 120-240V system you should have a reading between white and black as desribed, you should have nothing between the black wires and ground, however you can only test by completely disconencting them all, you may have a N-G bonding jumper in the output wirs giving you that reading
Jan 25, 2011 | Coleman Powermate Powermate 5000W...
I have a powermate 5000 (about 10 years old). I have installed a Reliance Transfer switch. Should I ground the frame to a grounding rod when plugged in. I obtained the manual(on the powermate) and the...
In any power generator installation it is always advisable to have a ground/earth rod (minimum 3 ft/1 metre long) attached to the frame of the generator, especially when connecting ancilliaries such as yuor transfer switch. The Earth and Neutral pins of the output sockets on the generator should also be interconnected. They are usually linked at the factory on assembly.
Dec 22, 2010 | Coleman Powermate Subaru 5000W Portable...
I have a Coleman Powermate Progen: model #PM0535202.02 ser. # 86310853. My generator does not have proper AC output. I have diagnosed problem and neeed to know where I can get a set of brushes for this...
Here is your manual for parts:
http://www.powermate.com/pdfs/2007/11/30/parts_copy_of_parts_diagram__parts_list_pm0534502__pm0535202.pdf
Item #10A
Part # 0050439
Go to this page and click portable generators. Then enter your Zip Code to find the nearest source for your part.
http://www.powermate.com/servicecenters.php
Or contact them here: Customer Service: 1-888-977-2622
Thanks for using FixYa!
Kelly
Mar 08, 2010 | Coleman Powermate Powermate 5000W...
How do you convert the (2) 240 volt outlets to one twist lock connector on a coleman powermate maxa 5000 er genset
Make an Umbilical recepticle adapter. Buy the recepticle install the recepticle in a 4" electrical BOX on a plate with two manufactured 3 prong power cords plugging into the 2 outlets and terminating at the new Box twist lock recepticle you made.
Feb 09, 2010 | Coleman Powermate Powermate 5000W...
Coleman Powermate Powermate 5000W Generator Logo
972 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
