Question about Kenmore 74602 Gas Dryer
Drum dryer has knocking sound coming from drum
  • 2 more comments
  • jr1791 Dec 31, 2008
    The knocking occurs once a rotation in the same position
  • jr1791 Jan 01, 2009
    The dryer has never been repaired, it is a Kenmore gas dyer, Mod#110-74622300. When the drum rotates there is a knocking sound coming from the drum (1 per revolution) at the same location
  • Bill Gilhooly
    Bill Gilhooly May 11, 2010
    Has the dryer been recently serviced/repaired? Is the type/model, Kenmore/74620 gas dryer?
  • Bill Gilhooly
    Knocking sounds can be caused by a few things, and it is useful to know the frequency of the noise. Does the noise occur once per rotation? Randomly? Or at the same drum position every time? More often, for instance two, three, or four times per revolution.
  • 91 Answers
Repl/ drum rollers that its should fix the knocking noise
Posted on Jan 03, 2009
My Gallery Series dryer makes an intermittent noise when i turn on the dryer. It sounds like the drum is getting caught up on something. It sounds like grinding gears. The noise comes and goes
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 08, 2011 | Dryers
Dryer makes a squeaky sounds durning cycle, it comes and goes, sounds about the same speed as drum is turning
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Dec 27, 2010 | GE DSXH43EAWW Electric Dryer
Dryer is knocking,on left rear side you can feel the knocking and when you press it knocks louder
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
pulley and motor.
Now is a good time to check the belt to see the belt condition for wear.
Please rate me
Dec 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
My Amana Dryer model # LGA60AW makes a knocking sound when drying
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Please rate me,
Thank You
May 11, 2010 | Amana NDE2330AY Electric Dryer
Dryer makes a sound as if there's a marble loose in some rotating part. It doesn't seem to be coming from the drum, because when I disconnect the band from the motor and hand rotated the drum at speed...
heatman101
ghhgfhf
Mar 21, 2010 | Kenmore Elite HE3 Steam 8676 Dryer
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Dryer making knocking sound
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also check the belt condition for wear.
Check your drum rollers for flat spots, if they have flat spots on them replace them.
If the drum rollers don't have flat spots on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Good Luck,
I hope this helps
Nov 13, 2009 | Kenmore 62602 Electric Dryer
Kenmore 74602 Gas Dryer Logo
112 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
