Question about Brother IntelliFax-4100e Fax
4100e brother fax i am unable to receive fax - Brother IntelliFax-4100e Fax
    Champion:
  • 320 Answers
If you are getting dial tone, then go tto the receive set up and scroll down to easy receive and then press set
Posted on Jan 20, 2009
How can I correct double or repeat image down a page?
Solutions - Brother International - Frequently Asked Questions
www.brother-usa.com/FAQs/Solution.aspx?...
Brother IndustriesThe text and images on my printed documents are ghosting or double printing. ...checks, or other media can cause reprinting or ghosting on the page. ... NOTE: This cleaning process may have to be repeated several times to remove certain ... Remove the toner cartridge from the drum by holding down the green lock lever ...Missing: intellifax ‎4100e
[PDF]FAX-4100e FAX-4750e FAX-5750e - Brother
https://www.brother-usa.com/.../UM_IntelliFax_4100e_E... Brother IndustriesYou can download the latest software documents ... Paper Cassette #2 (Option for FAX-4100e and FAX-4750e) .... repair or replace the Machine and/or ..... 4 Double-click the icon for the documentation you want to read. ... To return to the main page, click Back-OR-If you have finished your setup, ..... Repeating Letters .
Jan 30, 2016 | Brother IntelliFAX 4100e All-In-One Laser...
Why is my Brother Intellifax 4100e error says check paper size?
your paper error message means you probably received a document that wasn't the size of paper in the paper tray ,try legal sized paper,to dump the job stuck in your faxes memory ,this
problem happens a lot, theres reall nothing wrong with the fax/printer
Aug 13, 2014 | Brother IntelliFax-4100e Fax
Unable to receive fax on 4100e
Sorry, but you have to be more specific on what are you trying to achieve and what you have done so far.
Do you want the unit to automatically answer a call and receive the fax? If so, make sure that you have switched it to FAX mode (press the MODE button repeatedly until FAX is shown on the display). You can also set it to FAX/TEL mode, whereby the machine will answer the calls and signal (ring) if it is a voice call not a fax.
The default setting is for the machine to answer after 4 rings, refer to the manual if you want to change this value (you can download the manual here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr_B.pdf
If you want to manually receive a fax after you've picked the phone up yourself, then when you hear the other side fax beeping, simply press the START button.
Jul 21, 2011 | Brother IntelliFax-4100e Fax
Customer with Brother Intelifax 4100e cannot "handshake" with our Savin 816 multifunction. The Savin is receiving hundreds of faxes daily, and is also used to scan to document management, etc. ...
I have a fax line with packet8 which is a voip carrier. I am having trouble receiving faxes. I was told to change the baud rate on the fax to less than 9600. I don't know how to do it on my brother intellifax 4100e. can you advise?
Thanx,
Mar 22, 2011 | Brother IntelliFax-4100e Fax
We have the Brother Intellifax 4100E. It was working fine up until last week. Then it started not receiving faxes. We can copy, and send faxes, and receive the confirmation. I have checked the mode button...
Try calling the fax machine from your mobile and see if it picks up or if anything shows up on the screen of the fax machine. Is it possible that you have plugged the fax machine into the wrong telephone line? Try sending a fax to your mobile phone and see that the number is correct.
Mar 07, 2011 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e There is a message on the screen to change drum, and I already changed it. Also, there is a squeggy noize everytime we receive a fax. I tried taking the drum, carthridge and I...
1. Open the front cover and then
press Clear.
2. Press 1 to reset.
However, the drum may be defective and causing the noise. Try a different one if you can.
Nov 16, 2010 | Brother IntelliFax-4100e Fax
Cannot receive fax with voip line.
Fax machines are ANALOG devices. Any other condition is a ****-shoot.
Aug 12, 2008 | Brother IntelliFax-4100e Fax
Brother IntelliFax-4100e Fax Logo
386 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
