Question about Intermatic & Indoor/Outdoor Rain Tight Timer
Loss of power on new unit died sevral times
Do I need a new one
  • Joel Wiedeman May 11, 2010
    Can you give me a make and model number and a little more info about description please?
97 Nissan Sentra runs fine for about 2 miles then starts losing power and dies wont start back up for about an hour
Check Engine Light/Loss of Power Due to Throttle Body Unit ... > Problems > Nissan > Sentra
The electronic throttle actuator (throttle body) can fail causing a loss of power ... start it studders like it is running on 2 cyl. then switches to 3 cyl. then to 4. but ... Throttle body replaced on my 2006 Nissan Sentra 1.8 engine. ... I Was going up a hill and I tried to speed up, all of a sudden my car bogs down and completely dies.
Nov 17, 2015 | Nissan Cars & Trucks
I hive a 1990 1500 Silverado z71 off road ran good for about 3 minuets then would start to die out then die after cooled off would do same thing so I changed full pump and filter then realized there was no...
Cannot determine from the description of the problem if rewiring power to pump resolved the loss of the electrical power or not. Now when it dies, is there still a loss of electrical power? If there is still a loss of electrical power, ensure that the new wiring is connected to the 'Engine Switched' side of the power system. In other words, only when the engine is turned on, power is applied to the fuel pump. If power is good, mostly likely there is a clog in the fuel system (lines) between the pump and the fuel injectors. It doesn't necessarily mean trash was sucked out of tank, today's ethanol gas can trash a fuel system from the inside out. Being a 1990...vehicles back then were less compatible with ethanol. If pump has power and running, fuel lines may need a good flush (multiple flushes maybe to get it all). When it quits, a simple pressure test at the injectors may help determine if fuel is getting to engine. Keep it simple...walk the dog. Make sure you've got good pressure at pump, follow fuel line hand over hand to the next connection, test pressure again, keep going until you find loss of pressure. Good luck...these type of problems are not fun to troubleshoot, not difficult either, just time consuming.
Sep 27, 2013 | 1990 Chevrolet K1500
Ne demare pas quand il fais froid
check glow plug system light in dash will go on even with a bad relay
check at the glow plug itself also check the glow plug itself
check your block heater if this check out ok try warming up the ficm
the one mounted on the valve cover left side with a air blower for
sevral minutes (10 min ) on hi and if unit stars you need new ficm
work for me on sevral unit so far good luck
Jan 17, 2011 | 2004 Ford F350
Do I need a new battery. charged all night camera stays on for a little bit and turns off. Shutter only opens half way Help
Yes! you may need a new battery in that case, rechargeable batterie die over time. The sysmptoms you're saying definitely indicates loss of power and battery replacement should fix it. :)
Jun 09, 2010 | Samsung NV10 Digital Camera
Model No. 247=103A401 repair manual
You may be able to go to You will need the model number and serial number off the unit to get the information off the website. I googled your model number 247-103A401 and found sevral places to find parts and diagrams for it. The only drawback is the unit is from 1997. It may be beyond the websites files for the time.
Dec 28, 2009 | Heavy Machinery
19 tdi loss of power
I have a 1999 VW golf tdi with intermittent loss of power. The turbo will cut in for a few seconds, then die forcing you to change gear and get a small boost again. The turbo will not boost much past 2200 rpm. The cars computer has been plugged in at the garage and does not show any problems. Various people have said, replace turbo, air mass meter or just simply wash turbo filters in WD40. Can anyone help?
Dec 11, 2008 | 2001 Volkswagen Passat
This is a simple fix for any shop that has done these before. You need new belts/idlers and a ngeneral cleaning and alignment. Figure on $75 or so for each for parts and labor.
May 19, 2008 | Emerson EWC1304 13 in. TV/VCR Combo
Intermatic & Indoor/Outdoor Rain Tight Timer  Logo
52 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
