Question about KitchenAid KUDR01TJ Dishwasher
Leaking lower door seal on kitchenaid dishwasher model KUDM25SHWH
Dishwasher was leaking at bottom of unit so i order a new lower door seal when ordering i was told original seal was no longer available but a after market seal was available so i ordered it. new seal arrived and right away i noticed a big diffrences between the two seals old seal was larger and more rigid but i installed new seal. with new seal on i started dishwasher hey leak was fixed but by the time dishwasher started its third cycle it was leaking again stop dishwasher and opened door and there was the new seal on the bottom of the dishwasher reinstalled and tried again same results. help please it is a great dishwasher and would hate to have to replace it over a ten dollar part.
  • Anonymous Mar 15, 2014
    replacing bottom door seal
  • 121 Answers
Check door hinge.
Posted on Feb 15, 2009
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
I found some black plastic under the dishwasher and then found some more... it appears to be long as if it was the seal or something across the bottom of the door. Can you tell me what it is and what I...
Its hard to tell from the description what it is. Does it like item #4 in first link OR item #31 in second link. If it is item #31 in second link its soundproofing insulation that attaches to kick plate and has come loose,a couple dabs of super glue would reattach it to kickplate
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00003?blt=06&prst=&shdMod= item #4
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00005?blt=06&prst=&shdMod= item #31
If it is item 4 thatsa seal on bottom of door and needs to be there to prevent leaks
Gene
Aug 13, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
I have a kitchenaid dishwasher model KUDMOITJBLO installed as new unit in Oct. 2002 in a new home. Current problem is water coming from front door, bottom as unit starts wash cycle after filling. Leak is...
Hello, Thank You for using FixYa. I will be helping you today.I would start by removing the outer door panel remove the screws around the inner door to do this.Then close the door and start a cycle. Sometimes you can see obvious signs of leaks just by removing the panel too. But if not let it run and see if you see water leaking anywhere. You will see water in the bottom corners its normal. If water is splashing over those corners the check the lower spray arm gor damage or cracks it can cause this problem also make sure the screws under the spray arm are tight. also check the upper arm.
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid 24 in. KUDM01TJ - Multiple...
Water leaking from bottom of door
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uiopety
Apr 07, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
My KitchenAid Superba (whisper quiet ultima) started to leak out the front when it is running. Is this an easy repair or should we think of replacing the dishwasher? BTW - we love this dishwasher!
Hello. If the unit is over ten years old, I advise against repair. But if you do wish to consider repair, here are the things to look at
Main tub seal Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly. The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the: Lower rack Spray arm Spray arm support Wash/drain impellers Then pry the seal out of its housing and replace it. Door gasket or seal Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak. Water-inlet valve The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary. The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve. Hoses Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
Mar 18, 2010 | KitchenAid Dishwashers
Our KitchenAid dishwasher has been working great until just recently. It has started to leak small amounts of soapy water about half way through the process. I ran an empty load and it didn't leak. Ran...
Hi
Thanks for using FixYa. If you have nuisance water leaks around the base of your dishwasher, you may be using a detergent that is causing too much suds. Cut back on the amount of detergent you use, and see if that makes a difference.
Water that spills through the door vent is usually caused by improperly loading dishes. Leaks from the door itself may be caused by a faulty door gasket or door tightness adjustment. you should check the main tub seal, the door latch, the door gasket, the water-inlet valve, and the fill and drain hoses.
Also make sure the dishwasher is sitting level (you can adjust the front feet up or down, and many units have some type of levelers at the rear).
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repairperson.
An older dishwasher may corrode at the bottom, but this is fairly uncommon. If this is the case with your dishwasher, it's time for a new one.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Answer 2 (Door seal replacement)
Hi
Water under the dishwasher may be originating from a leaky hose or loose hose connection. Remove the lower front panel, and check the hoses. The pump seal may be defective, too; replacing this is a job for an appliance repair person. The door seals on this Kitchenaid dishwasher are pressure fit into a metal channel that runs along the inside of the wash tub.
To install, simply remove the old seal paying close attention to which way it was installed, apply a bead of adhesive inside the channel, then install the new seal in the correct direction. A test fit prior to applying the adhesive is a good idea and if you are having trouble with one side being to long, try folding the seal in half, take hold of the looped end, and insert it under the door latch. The reset should go in properly. The new seal will be a tight fit which is the way we want it so it may take some force to get it fully seated. If the door is hard to close, then the door seal needs some more work.
Thanks
Rylee
Nov 09, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
I have a kitchen aide dishwasher ~ only about 6 yrs old ~ and it's the higher end model with the Wood panels , anyway , Its leaking water on the bottom ~ Is that the main seal ? and How hard is it to...
Hi
Thanks
Rylee
Sep 15, 2009 | KitchenAid Dishwashers
Door still leaks after replacing bottom seal
the bottom seal isn't actually a seal, rather it serves as a splashguard. I had the same problem with the same model and started by replacing what I thought was a seal located at the bottom of the door.
Check if the screws on the top half of the pump (located under the lower spray arm which needs removed first) have become loose. The screws were barely in the threads which caused a stream of water towards the door and leaked between the splashguard and bottom edge of the tub and onto the floor.0d084cc.jpg
Dec 20, 2008 | KitchenAid KUDC25CH Dishwasher
I have a Kitchenaid KUDS25SHBL1 dishwasher that is leaking from the bottom of the door. I replaced the main gasket around the body that the door seals against, and it is still leaking.
Have you removed the outer door to check if the leak is coming from inside the door . also check the bottom door seal ? also check the around the soap dispenser as I have had to silicone around them to keep them from leaking before..let me know if this helps at all.
May 11, 2008 | Dishwashers
Frigidaire Dishwasher Leaking
I just found a service release number for my Frigidaire dishwasher that says it applies to Serial numbers TH632 through serial number TH737 made in 2007 for a replacement kit for the door seal at the bottom of the door. The bottom door seal has been changed, adding side seals that restrict the water surge from the center spray arm. The part number for the new seal is p/n 154588201. This seal can be replaced without removing the dishwasher or either of the door panels.
The seal is located on the bottom of the inner door panel and appears as a cream colored flexible
rubber blade bonded to a milky white colored plastic strip. To remove and properly install
replacement follow the instructions carefully.
1. Replacing this seal can be accomplished without disconnecting power from the unit.
Always use extra care when electrical power is present while serving an appliance.
2. Open door all the way down and remove lower rack. Set rack aside to a safe location.
3. Locate the seal on the bottom of inner door panel. Facing front of unit, the right side of the
seal can be pulled down slightly to facilitate removal.
4. Pull seal straight into the tub from right side.
5. With seal removed, and before installing replacement seal, locate the channel in inner door
panel that the seal mounts into. Locating this channel before installing the replacement can
make this procedure easier.
SERVICE FLASH
DW071
6. Place the new seal on a flat surface and measure from the bottom of the seal, (See Figure
1 to determine bottom of seal), up 3/8 "of an inch and place a mark with a pen or marker on
both ends (See Figure 2). If needed, scribe a straight line between these two marks this
will give you a guide when installing seal into the inner door panel.
7. The seal can only be installed one way. The end that holds this seal into the inner door
panel has a ½ inch notch cut in the right side. This notch allows the seal to be installed
around the end of the inner door channel that holds the seal.
8. Line up the seal along the bottom of the inner door panel and start from the right side, push
the seal into the door channel to the line marked in step #6.
9. With seal in place close the door, the tub will align the seal as needed.
10. Reinstall lower rack and operate unit to check for leaks.
If leaks continue to occur at the bottom corners, order Splash shield kit 154701001 for
dishwasher.
Before installing the kit remove and reinstall the lower door seal. To install the lower seal make
sure you measure up from the bottom of the seal 3/8 of an inch and mark the seal, do this on
both ends. This locates how far down the seal needs to be before closing the door. Do not
install this seal without measuring it first. After the lower door seal has been re-installed then
install the splash shields according to the instructions accompanying with the kit.
Sep 18, 2007 | Dishwashers
KitchenAid KUDR01TJ Dishwasher Logo
1,052 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
