Question about Avanti G20AW-1 Gas Kitchen Range
Gas ignitor Our gas stove top keeps trying to ignite even though the knobs are in the off position. It started after I took off the knobs to clean them. The model number is sf385pee
  • 78 Answers
Try pulling the knobs out just a bit. sounds like one is jammed.
Posted on Dec 30, 2008
My stove is making strange clicking noises. please help.
It sounds like the ignition knob is stuck in the "ignitor" position. Try taking it off, clean it and adjust it. If that doesn't work, it will have to be replaced with a new one. If yu leave it alone, it will probably wear itself out. Just make sure that the gas valves on the stove are in the off position so that they don't accidentally light on their own. Good luck
Jul 13, 2010 | Cooktops
Maytag stove top gas ignitor keeps clicking
clean the bottom of the knob by using vaccium,remove the knob,pull it then clean the area of the control knobs.
Jul 01, 2009 | Maytag MGC5430 Gas Cooktop
Tried to clean top of jenn air stove
If this is a gas stove, you've shorted out the ignitor circuit.  If it is electric...you may have gotten some of your cleaner into one of the controls.  See what doesn't work and trace from there.
Dec 14, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Igniter
Does the knob control both the gas and spark, try turning on the knob only, if it starts to spark right away then it is possible that the switch is bad. because most of these units are designed where you turn on the gas then push in and hold the knob to ignite then release and spark should stop.
Dec 08, 2007 | Dacor Epicure ERD30 Dual Fuel (Electric...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
Avanti G20AW-1 Gas Kitchen Range Logo
376 people viewed this question
Top Avanti Kitchen Ranges Experts
Craig Butler
Craig Butler
ray gallant
Are you an Avanti Kitchen Range Expert? Answer questions, earn points and help others
