Question about Dell 1100MP DLP Projector Multimedia Projector
Why is my projection dark and muddy compared to the brightness on my computer screen?
I've just started using this projector and I'm no expert at it. I created a movie with iMovie (on my Mac), connected my Mac to this projector via VGA cable and adaptor for mac, and projected it in a darkened room about 10-12 feet from the projector onto a projection screen. The images on the screen were very dark and muddy. The images on my computer screen were bright and clear. Switching to another Dell projector (a friend's), it all worked fine. Seems this projector has been fine in the past. I loaned the projector to other novices recently. What can I do to maximize the brightness and sharpness with what I described above? Thanks! gadee
  • Gayle Dee May 13, 2007
    Thanks, John!! thanks for helping me get on the right track. Much better!
    Problem Solver:
  • 12 Answers
Clean lenses in light engine.
Posted on Dec 17, 2012
  • 38 Answers
A lot of these problems aren't worth the cost to fix. If you havent fixed the problem I may be interested in buying your broken projector from you as a parts machine.
Email me at: nalexandrov251[A-T]gmail.com and we might be abe to work something out.
Posted on Dec 08, 2009
John here, customer advocate at Dell headquarters. If you can nvigate to the On Screen Display Menu, you should see an "all images" section on the main menu. There you will find brightness, contrast, color temp, white intensity, and gamma controls. You should be able to make adjustments from that menu to sharpen and brighten the image.
Posted on May 11, 2007
Can I project outdoors with an Acer PD113 ? and How big will the image be?
Not sure of the lumens or brightness of this model but in the dark it should be bright enough. Most projectors will do up to a 300" diagonal image.
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
Sep 01, 2014 | Office Equipment & Supplies
Gradient brightness
Make sure all your cords are plugged in. Try restarting the projector, make sure nothing is blocking the lenses. If the does not help, Call Radio Shack or Staples.
Nov 06, 2013 | Epson PowerLite 84 3LCD Projector...
Image very dark
go nto the main setting and clear everything and reset it you will have to start from new but the brightness will improve
Apr 29, 2013 | Optoma MovieTime DV10 Multimedia Projector
I have a Mitsubishi 60"
there may be dust behind the screen & also on the reflecting glass. u will see that upper back portion cover is removable. remove it & see that glass there is glass on inner side of cover. clean it, also clean the screen. u will see there are 3 picture tubes faces on bottom side, clean all of them.
if it does not work then u can increase brightness of tv by increasing "screen" control of tv which is on the lower back portion of tv. this can be done by any tv repair expert only.
Sep 05, 2011 | Philips Magnavox 51MP392H Rear Projection...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
I purchased a discover wonderwall entertainment projector - when I play movies on it the picture is VERY dark - you can really see faces that well in some scenes. how can I make it get a better picture?
Tries the screen functions adjustment like brightness or contrast in higher levels?U own the projector for a while?Might require a projection lamp change.
Jan 01, 2011 | Televison & Video
I,ve got a red spot in the screen i replaced the bulp but stil have the problem
it is most likely a burned polarizing filter. There is a polarizing filter on the blue light channel and another on the red channel. When black, or other dark colours are displayed, the red polarizing filter is supposed to block ALL of the red light being projecter. If the filter is burned, some light slips through and creates a red tinge on the projected image. If the red tinge only appears on dark images, but is absent when the images is completely white, a damaged filter is likely the problem.
Seems its hard to buy them. Best bet is probably buying a broken projector from ebay and stealing the filters out of it.
Oct 04, 2010 | Toshiba TLP 670 Multimedia Projector
Replacement lamp not bright
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Mar 05, 2009 | Mitsubishi WD-52725 52". Rear Projection...
632 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
