Question about Nikon N80 QD 35mm SLR Camera
N80 Help I am wondering what "FE E" means when the camera is in Manual mode. It only allows me to have my f-stop at 5.6 and the shutter stays almost completely closed. When I change the f-stop, I'm not allowed to take pictures and "FE E" just flashes. Any ideas?
  • 37 Answers
You can only change the aperture using the command/sub-command dial on your camera.  The aperture ring on the camera must remain locked at the smallest setting (largest number).
Posted on Oct 23, 2007
Shutter will open but not close
Sounds like the camera is not getting battery current, since that is how it will act without batteries. Does the meter needle respond to changing light when switched on? If not, check battery polarity -- the + end touches the strip at the bottom of the battery compartment, the - end touches the battery cap. If that all checks out right, one of the wires connecting the battery compartment to the innards may be corroded or loose.
Sep 01, 2013 | Nikon FE 35mm SLR Camera
For use on a non-Hasselblad camera, can I use the aperture preview button (which locks) to set aperture?
There is no communications between the camera and lens. When using a set up like this everything becomes manual and you must remember to stop down the aperture to your taking aperture before releasing the shutter. I don't know what camera or format you are going to use this lens with but assuming it is a digital "bridge" (a camera that is between an amateur and a pro) or a professional the sequence would be the same.
To view, focus and compose the lens would be set in this case F2, to select the correct light meter reading the lens is set (stopped) down to the taking aperture. The modes I've used for this have been mostly manual but lately I found that "AV" worked equally well and the camera metered to the proper exposure. Most times the camera was mounted on a tripod and the shutter was released with a electronic shutter release.
Sequence for taking a photo for me anyway was/is (with the camera mounted on a tripod) focus, compose, stop down to taking aperture, check metering and release the shutter if in AV mode or manual mode to set the shutter speed and release the shutter.
You will find that all makes of digital cameras will function differently so what sequence works for one won't work on others. This meaning I have had digital cameras that wouldn't meter through anything other then the lenses meant specifically for them.
Problems that I've had. Forgetting to stop down to taking aperture (like Duh), not fine focusing (manual), not trusting the in focus indicator, forgetting that the viewfinder is/was only 94% of the scene. Once a little time has been spent with a lens set up like this the rewards are far beyond the trivial annoyances. Have fun with it
Jan 12, 2011 | Hasselblad 110mm f/2 FE Zeiss Plannar Lens
How do I take videos with my Olympus FE210? It doesn't seem to be covered in the manual
Just turn the mode dial to the picture of a movie camera. Press the shutter button to start the movie and press it again to stop.
Jan 21, 2010 | Olympus FE-210 Digital Camera
My olympus FE-240 takes blurry pictures in night mode.
It's you...in night mode the shutter stays open much longer...plenty of time for you to move the camera. Use a tripod.
Dec 17, 2009 | Olympus Stylus 700 / 700 Digital Camera
Blurry sports pictures that are inside and are fast moving b(basketball). Is the problem my lens? I am using a Canon XTI. I am a pure amateur just wanting pics of my daughter playing ball.
If you're shooting in the full Auto mode, you are not taking advantage of the capabilities of your digital SLR. Your pictures are blurry because the shutter has to stay open long enough to properly expose the picture, but the people are moving while the shutter is open. You need to increase your shutter speed or increase your ISO, which means you have to select another mode on your camera. You could invest in a "faster" lens, which means that it can allow more light into your camera, but is also more expensive. Try this excellent tutorial on using a digital SLR, then try it out with your camera (use your camera manual to find the correct mode selections, etc.)
http://www.photonhead.com/beginners/
Look at the topics under Photographic Concepts to get an understanding of the relationship between shutter speed, aperture, and film speed (ISO).
Jun 23, 2009 | Canon Digital Rebel XT / EOS 350D Body...
Error msg
Hello!
Southern Photo Technical Service is a Authorized Service Center for NIKON.
You have a shutter failure!!
We do service the camera model you mentioned and the standard cost to Clean, Lube, Repair and Adjust all functions to meet manufacturers
specifications is $169.00 plus return shipping.
All repairs have a SIX MONTH WARRANTY!
Include a copy of this reply and
receive a 5% INTERNET discount on your repair!!
Bring it in, or
Pack your equipment securely and insure it properly.
Send it to:
37 NE 167th Street
N. Miami Beach, Florida 33162
305-653-7355
May 28, 2009 | Nikon N80 35mm SLR Camera
Shutter staying open and only closing when dial moved to M90 or B
It sounds like your cameras need a CLA (clean, lube and adjustment). Occasionally when this has happened to me, i noticed that it was the foam on the mirror bumper that had gotten all deteriorated and gummy and as such the mirror would 'stick' to it when it flipped up. Changing the foam seals might do the trick.
Switching to M90 means that the camera is in Manual mode whereby it is not relying on the electronics at all in the camera. When your battery dies in mid shoot, you switch to M90 and you shoot manually at a fixed speed of 1/90 second. Of course your light meter won't have power, but if you meter manually or go by the 'Sunny 16' rule, you can adjust the aperture and get your shots.
Yes, moving the shutter dial to M90 should release the mirror back down, if it is stuck up.I'm assuming of course that you didn't manually set the mirror up anyway... Test it out with brand new batteries!
Nov 20, 2008 | Photography
Double Exposure The Easy Way????
Not all cameras can do this. The Nikon N8008, for example, allows you to specify the number of exposures for each frame. The N80, on the other hand, doesn't. You have to cancel the Multiple Exposure mode to advance to the next frame, then set M-E again.
Sep 08, 2006 | Nikon N80 35mm SLR Camera
Shutter priority mode?
s I understand it from what I have seen on the Web, the 3000Z can operate in several modes: 1. Fully automatic (camera select both 2. Manual (user sets both aperture and shutter speed). 3. Aperture Priority mode - user sets aperture and camera chooses correct shutter speed to get a good exposure Apparently there is no Shutter Priority mode (user cannot set only the shutter er speed and allow the camera to set the aperature to get a good exposure). This option is available on the Epson 850Z camera and this seems like a silly ommision to make on a "high-end" camera like the 3000Z.
Sep 13, 2005 | Epson PhotoPC 3000Z Digital Camera
Nikon N80 QD 35mm SLR Camera Logo
99 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
