Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
I have a hoover windtunnel v2 the brushes underneath wont turn ? its suppose to be beltless what do i do to fix this
  • Anonymous Feb 12, 2009
    same problem....took apart,,,,could not find belt. brushes wont turn
  • 57 Answers
Are you sure it is beltless? What model do you have? Looking at another manual there may be a seperate on off switch for the brushes but would need to know your model to be sure.
Posted on Jan 06, 2009
Why won't my brushes turn
most likely stripped gears on the end of the brushes. (beltless model?)
Nov 21, 2011 | Hoover WindTunnel V2 U8148-900 Upright...
ARE THE BRUSHES SUPPOSED TO TURN ?
the unit has a safety switch in it that only starts the brushes turning when you have the unit in the reclined position for using it on the carpet.
Nov 04, 2010 | Hoover WindTunnel V2 U8148-900 Upright...
The Rotary brushes do not rotate/spin when the unit is turned on.
check the belt it may be stretched or broken...also carpet and hair or other debris around the bruches may have it in a bind,,..remove the 2 screws holding the bottom on to check this
Jan 03, 2010 | Hoover V2 U8140-900 WindTunnel Upright...
Auto brush on hoover windtunnel doesn't spin anymore
I have a Windtunnel S3765 with the same problem - and it has very little use so I'm confident it isn't wear. I find that the wheels do not raise the agitator brush sufficiently high to reduce the drag caused by excessive contact with the carpet. If I raise the front a bit the brush spins as it should. It also works if I take the housing apart and use it without ..... but this is tricky.
Unfortunately I haven't figured out a way to hold it up efficiently. I am toying with afixing something to the bottom of the housing to raise the front enough to give the brush a little more room.
Dec 20, 2008 | Hoover U6630-900 WindTunnel Bagless...
Hoover Wind tunnel V2
Either the brush rolls are bad, ends are bad, or the gear housing/motor asm. is bad and will have to be replaced. ee84874.jpg
Oct 23, 2007 | Hoover U8147-900 WindTunnel V2 Bagless...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
177 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
