Question about Kenmore 53612 / 53614 Side by Side Refrigerator
Freezer temp what should i set my freezer temp at? i have a side by side hot point
  • 242 Answers
Hello I can help with this problem , You can set it to the factory setting thats normaly in the middle , wait 24 hours for temps to equalize and check temp in freezer with an accurate thermometer it should be -10 to +10 deg. Far. to adjust temp move dial up or down only one digit at a time and wait 24 hours on each adjustment until its at a correct temp.
Posted on Dec 30, 2008
4 Suggested Answers
dididsaythat
  • 291 Answers
SOURCE: Hot Point Side by Side. Freezer works, Fridge not cool enough
check freezer for frost build up and if fan blowing, check condenser make sure clean, and fan blowing, check vents in refrig. make sure no blockage, freezer control should be in the middle setting, you can try turning that to Warmer Freezer allowing MORE air to refrigertor side.
Posted on Sep 03, 2007
SOURCE: Hot point Fridge/ freezer
All the cooling is in the freezer and the control in the fridge side only controls a damper to let in cold air as needed. To do what you want you have to replace the thermostat to a lower temp rated unit
Posted on Nov 23, 2007
aborcass
  • 2651 Answers
SOURCE: The strip between freezer and fridge is very hot
sounds as if you either need to clean the coils under the unit,they are clogged and unable to disapate correct amount of heat, or your fan mounted behind the unit, next tothe compressor has failed..YOUR UNIT IS WORKING EXTRA HARD TO GET RID OF HEAT.check those 2 places
Posted on Jun 15, 2009
Stumped by Damper Control malfunction symptoms
U seem to have a good handle on things but the flapper door is still not operating properly. Rather than create more agita for yourself, you just might want to consider replacing the assembly if not that expensive. OR experiment with various flapper door openings till you get a more reasonable refrig temp since 25 is too low. Aim for 35 - 38 degrees.
Sep 01, 2015 | Refrigerators
Freezer is cold but food isn't frozen
Deforst freezer and ref. wipe dry. Reset controls to starting point.
Check temp. 0 in fez. 38-40 in ref. keep advancing settings until you reach temp. Also, vaccum behind unit
May 02, 2014 | Amana 22.6 cu. ft. Side-By-Side...
Bottom of ref colder than the top
There is an air duct between the freezer and the refrig which has to be set for what is in the bottom drawer ,either fresh veggies or meat.
check the settings.
is it defrosting as it should?is there snow type frost on the evap cover in the freezer?
if this isn't the problem very limited opening of the refer can cause
the cold freezer temp to migrate to the frig side due to inactivity .
did you actually take temps of both sides around the mid point of both sides to see if they are correct .ref 35-37 freezer 0_+5 at normal settings.
many things can cause this issue.you must eliminate them one by one.
Apr 05, 2014 | KitchenAid Superba Architect KSCS25INSS...
Sr s22ftgrs bad freezer temp
HI PAVLOS.from what u say it sounds like it just needs a good good service.clean all vent holes and blow the hell out of the condenser unit .it should work.ventilate well.could be heating up and stopping long.good luck ali
Jul 12, 2012 | Samsung SRS20DTD Side by Side Refrigerator
My freezer temp registers 28 - 36, I cleaned out coils, I notice that there is a fan in the back bottom right side, not sure what should make that run. My Ice is slowly melting. I had the freezer setting...
That fan behind the refrig , is the fan that cools the compressor . It should be running any time the compressor runs . If not running , replace it . The center divider between the fridge and freezer ( front strip ) should be getting hot to the touch if the fan is not running .
Sep 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kitchenaid superba refer side by side
its normal for the temperature to stay around 28 degrees farenheight int the bottom drawer. (fresh cut meat keeps better at his temp). you can adj the temp slide near the bottom of the refrig next to the botom drawer to help adj temp. veggies will almost always freeze in the bottom drawer. also adj the temp controls to a little bit warmer to help as well.
Keep in mind the mid point settings on your refrig is just a starting point for you to adj to where it works best for you and your usage..
Dec 17, 2007 | KitchenAid Superba Architect KSCS25INSS...
Nov 22, 2007 | Samsung RS2578BB Side by Side Refrigerator
Aug 27, 2007 | Refrigerators
Kenmore 53612 / 53614 Side by Side Refrigerator Logo
183 people viewed this question
Top Kenmore Refrigerators Experts
Jim Goldsmith
Jim Goldsmith
Richard Roth
Richard Roth
deton8 von Splosion
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
