We had this problem too. We switched to the Electrosol tabs (with the red dot in the middle) for soap, and it seems to have fixed the problem. Make sure you have the rinse aid in there too. Good luck!
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Dishwashers have a part usually called a separator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Well, that usually happens if the water in the area has too much alkali metals, such as calcium and magnesium.
Try putting some salt together with the detergent before you start the cycle.
And if it still does, try washing the finished dishes again with clean water, i mean, without detergent...
are you in a hard water area such as florida ? do you have a water softener? if so take a can of frozen concentrate orange juice and put the frozen hunk in the bottom of dishwasher and run for one cycle. the citric acid will dissolve undisolved soap . this works much better. than vinegar which will only remain through the first cycle and then drain out as for the already grey glasses wash them in a solution of equal amounts red wine vinegar and water with just a touch of dish soap using a sponge.
white film generally shows that there is not enough salt in the dishwasher, this is not normal salt like on your meal, you buy this from the detergent section of the store, add salt through the part where it says "S" unscrew the cap and put about 2 cups of it in, while filling with salt water will overflow out of the same place, this is normal
this will start to work after about a wash or so
if the salt is fine then check the heater on the machine, make sure its warming up etc
if i have helped please rate me
