20 inch tv.
This is not a problem specific to flat panel televisions. In fact, it's not a problem at all. The documentation that came with your TV remote will have instructions on where to get the code and how to program it into the remote. Basically, you'll need to refer to the documentation of the device you want to control with the remote. It should list the code for that device. Then use the documentation for the remote for instructions on adding the code.
Hope this helps
Randy
SOURCE: Need Comcast Remote Code for Samsung LN32A330 TV
I contacted Comcast and here are your codes for the three way remote with DVR Samsung 10812, 10766, 10814. I have the same TV Samsung LN32A330 and it was the very first code for my TV! Hope this cuts down your frustration!
SOURCE: prive lcd tv remote codes
no manufacture has that brand in the code list. but soyo did come out with their own remote that will work satellite/cable boxes. Go on their website. www.soyo.com
SOURCE: code for Vizio tv
Unfortunately, those remotes only take a 3 digit code. I bought 2 new remotes, which do take 4 digit codes, but the code(s) for the Vizio do not work (or partially). I found that the 4 digit codes for the Goldstar and LG work better than those provided for the Vizio, but still not as good as the original Vizio remote.
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
programming DTA remote to Viore 26" tv
the orig remote does not work, the model number can't be seen. can the viore remote rc2001v work on the tv viore 22 inch lc22vh56pb? if not, what viore model remote be used, don't want to use a universal remote.
