Question about Canon BubbleJet i320 Printer
Problem Powering On
When powering on the printer, cartridges slam right, then slam left, then stop hard left.
Power light flashes orange 2 times followed by longer green.
Documents sit in queue and nothing happens. Finally a window indicating a printing error has occured.
Have unplugged and replugged and tried everything I can think of.
Hope you can help.
    New Friend:
Excellent start. Indeed the tape is the position fix for the cartridge carriage. From a paper jam, the tape was dislodged from the slot in the sensor housing on my printer. You could see the tape in front of the sensor housing when you remove the blue cartridge. The fix is to remove the four screws visible in the holes when you open the scanner lid. A T10 Torx tool is required. Tape the scanner housing to the mid body housing to keep the two parts together. Carefully lift the taped housings from the bottom base. Be careful as there are several signal tapes on the left side. There is sufficient slack to prop the housing on the left side when removed. Locate the black sensor tower on the circuit board behind the blue cartridge on the carriage. The position tape should be in the slot in the sensor housing. Be sure its not twisted or dislodged. The position tape is suspended by metal tabs on either side of the assembly. Do not mess with those tabs in any way or the device will loose its carriage position accuracy. Once the tape is in the slot, carefully re-install the printer housing case. Be sure the cases join properly. Drop the screws in the holes and slowly turn the screws backwards to find the original groove for the threads. When you feel the screw drop in the original thread groves, reverse the rotation and seat the screws in place. If that was indeed the fault, reconnect the printer and you should be good to go. It's time for a reward for the tech!
Posted on Apr 15, 2013
    Master:
  • 461 Answers
Open the cover and look for a strip of plastic that the cartridges move along. BE VERY CAREFUL NOT TO DISCONNECT THIS PIECE. If you can access it use a damp cloth to wipe any ink/dirt from this - DO NOT use chemicals as there are markings on this strip that are used for positioning. The slamming is caused because the printer cannot read the cartridge position.
Posted on Dec 31, 2008
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
If it is a Canon printer:
Clear the EEPROM
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD over current error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Nov 16, 2010 | Office Equipment & Supplies
Pixma mp150 E5 flashing and b + c flashing and warning light on! have recently put in cartridge world inks but have already printed with them now its playing up each time you try to use printer.
Canon printers MP 160 AND MAYBE OTHERS
A) E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
B) E27 - it is code for reset absorber (EEPROM reset or Waste
ink counter reset) and follow the described below
procedure:
2) When the Power is lit, press the Stop/Reset button two times while pressing and holding the Power button.
4) When the on/off lights in green, press the Stop/Reset button the specified number of time(s) according to the
orange and green, starting with orange.)note: press 4 times for waste ink counter reset.
button pressing
5) Turn off the printer.( it must be turn off)
then turn it on again.
Only in B) case you can enter into "service mode", in A) case or if have e.g. paper jam, or another error you CAN'T enter
the "service mode"
Try it
Anonymous see A) case: E5, E6 or E4 - it is cartridges error - to fix press the "stop\reset" button for 5-7 sec. and then release
it.
Mar 17, 2010 | Office Equipment & Supplies
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
BJC55 Printer not printing
There are some possibilities due to the above phenomena. Let's discuss about it:
1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
Hope these help.
YBC (/\)
Nov 01, 2008 | Canon BJC 55 InkJet Printer
Error Code 6A00
I have the Canon Pixma iP4000R printer. I had an error code of 6A00 and my power light was blinking/flashing green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange-green-orange (12 oranges).
I tried the “waste ink counter reset reset” procedure: Power on while holding the stop/reset button and pushing the service button twice, then pushing the stop/rest button 4 times to clear the error, but that didn’t work.
My ink cartridge carrier wasn't moving-staying in the center. I thought I had a paper jam.
I looked at a few blogs about my error on other Canon Pixma models and they kept talking about “sponges”.
The following is what I discovered that cleared my error and now my printer is back to printing!
The “sponges” are 2 hard pieces of absorbing plastic or something of the like. I was looking for a softer material like the long thin gray foam strip material in my printer. The 2 "sponges" on my Pixma iP4000R were next to each other-one was rectangular and one was square-like. Originally they were white but the ink made them black/navy.
The "sponges" are located on the right under where the ink cartridge carrier "rests".
I didn't see the sponges at first, as there was a white backwards “L” shaped plastic piece that had a spring attached to it. The “L” shaped piece was moved forward out of its place. I used my pen tip and pushed that piece back and found that the rectangular "sponge" had popped out of its place.
I used a pen tip popped both “sponges” out and rinsed them with water and voila they were once again white. I think the rectangular one had so much ink on it it popped itself out of place.
My error is gone and I can print again!
Apr 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Canon BJC 3000 does not print - 6 orange 1 green
Clean the connectors located on the Printhead and the Printhead Carrier... It solved the problem in my case...
Nov 11, 2007 | Canon BJC 3000 InkJet Printer
Canon Pixma MP150 Error code E 42
Had exact same problem. Scanner light should come on at power up. Found ribbon cable connecting scanner unit to base had come unplugged from socket on circuit board. The ribbon cable is one of three found near back hinge of scanner and is hidden underneath the other two. It should drape over the edge of circuit board and then plug into small recepticle on inner side of board. I plugged it in and printer works again. Hope this helps.
Nov 04, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Printer will not print
This worked perfectly for my printer:
Waste Ink Counter Reset
Power off printer and covers closed
Hold down the Resume button then press and hold POWER, the Green Indicator will light. While holding down POWER , release RESUME
Double click (2 clicks) RESUME then release BOTH POWER and RESUME and wait still the printer stops blinking.
When the indicator lights steady, press RESUME three(3) times. The indicator should be ORANGE.
Press Power to set data
I got the solution from the Internet at the following link:
http://www.fixyourownprinter.com/forums/inkjet/15620
Hope this helps.
Mar 05, 2007 | Canon BJC 3000 InkJet Printer
Canon BubbleJet i320 Printer Logo
118 people viewed this question
old marine
old marine
