Question about Samsung CLP-510 Laser Printer
How do you tell when you need to replace a toner color?
I am looking for something that will tell me when the different toners need to be replaced. How do you tell?
  • Anonymous Jan 18, 2009
    Ususaly on LED display is written when and which colour is low. But now, I don't have that message and when I print there is no blue color. I know that I have to replace blue toner, but where is the LED warning?
  • 18 Answers
The printer's LCD will tell you when to replace tones, you can also use the front panel to check on their 'life' so far.
Posted on Jan 04, 2009
We can't figure out how to get the toner out to change it?
Consult the user manual there are step by step instructions.
When you open the front door you see instructions on how to remove the toner bottle by simply look for any green noble or different color where you see drops of tone.
this nobs when turned in the direction indicated(mostly) clockwise you find that you have loosen something ready to be pulled. for toner you need to press and turn clockwise. when replacing it has the slots mind them something must go there. MIND THE INSTRUCTIONS WHICH ARE ALREADY THERE.
Jul 13, 2011 | Canon imageRUNNER 210S Copier
I have a HP Color Laserjet 2025. I recently replaced the color cartridges and when I tried to replace the black toner cartridge I got the message - "remove the shipping lock on the black toner...
My suggestion is to put the 2 cartridges next to each other and look at them as closely as you can. There has to be a difference between the one that works and the ones that give the error.
Something that just occurred to me. Check the slot where the black cartridge sits. Check it for something that could have fallen off the original cartridge and is wedged in the slot. Compare the slot with another cartridges slot.
Because one cartridge works and others don't, it tells me it's a physical(hardware) problem not electrical.
Jul 07, 2011 | Office Equipment & Supplies
How would i know which color of toner is need to change?
The life of the toner cartridge yield depends on the amount of toner that print jobs require. The actual number may also be different depending on the print density of the pages you print on, and the number of pages may be affected by operating environment, printing interval, media type, and media size.
If you print a lot of graphics, you may need to change the cartridge.
The machine uses four colors and has a different toner cartridge for each one:
yellow (Y), magenta (M), cyan (C), and black (K).
    The status LED and the toner-related message on the display indicates which each individual toner cartridge should be replaced.
    Trust this helps. Please vote. :)
Dec 11, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Samsung clp-510 .The image had bad color
please shake well to your toners.then verify your toner. if any scratch is appear then please change the toner.
Mar 20, 2009 | Samsung CLP-510 Laser Printer
HP LaserJet 2820
Push the button to align another color and open the door and take notes on where the carousel should be when changing a toner, Not sure why it would bypass yellow altogether but may be resolved by manually changing out the yellow. When you open the door to the toner compartment there should be something on the door that depresses something in the machine which will unlock the carousel and allow you to turn it by hand when you depress the same lever with some type of tool that will fit in the slot. Rotate the carosel until the yellow is where it should be when replaceing it then let go of the locking mechanism and replace the yellow toner. hopefully between changing the toner out and powering the machine off/on will get you back in business... Hope this helps you out and if it does please list as a fixya... if not, you may need to upgrade the firmware and that's not to hard if your on the network already...
Sep 24, 2008 | HP LaserJet 2820 Printer
Toner showing empty
first, if you refilled your toner, the printer will always tell you, that you are not using original toner and red light will blink. second, if printer tell you every time to replace different color, then you need to clean a chip reader and chips on toners. take out all toners and pc drum. under toner rack there is a chip reader, clean it with pressure air and reinstall
Jun 03, 2008 | Konica Minolta magicolor 2400 Laser...
Rotate Toner Button and Replace Cartridge Messages
Hello
take out all toners and pc drum, use pressure air to clean chip reader under the toner rack (right side) also use some alcohol to clean chips on toners and reinstall.
May 20, 2008 | Minolta magicolor 2400W Laser Printer
Samsung CLP-510 Laser Printer Logo
73 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
