Question about Sony CDX-F7700 CD Player
Doesn't recognise cd
When inserting a CD or when pressing the source button It doesn't see it. Just goes from Aux to Tuner. Any Help is appreciated. Gar
4 Suggested Answers
Ps3 Repairs
  • 42 Answers
SOURCE: Sony Xplod CDX-S2210S
It is more then likely your faceplate has become non functional, and if so the cd player is almost none functional. If you can remove the faceplate try cleaning the connections that clip into the cd player. But by the sounds of it, your face plate is die'ing out on you. Sorry
Good luck,
IF you need any more help just ask.
Posted on Sep 11, 2008
  • 10594 Answers
SOURCE: Sony CDX-S2200 CD Player Problem
Please press Reset switch in CDX-S2200. You can see it if you de-attache front panel.
If problem still exist, then you need to replace IC300 " 6-705-360-02 " IC TDA8588BJ/N2/R1
Posted on Oct 02, 2008
  • 6 Answers
SOURCE: sony cdx gt200
Posted on Nov 13, 2008
  • 3 Answers
SOURCE: No sound from cd or aux on CDX-GT32W
Just connect together the solid blue wire on the main harness to the radio with the blue/striped wire. The blue wire is for the power antenna and the blue striped is for the remote amp. but if not connected together only the fm/am has outputs to the line output RCA jacks. I learned this through Sony's tech line and it works perfectly now.
Posted on Dec 15, 2008
0 characters
1 Points
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
Yes, also.... I am trying to use my AUX input but "AUX" is not an option on the Source menu. The only options are tuner and CD.
In order to use the Aux, you must connect the source to aux port, then using the source select aux and you should hear the sound coming out.
Here is the link to the manual:
Feb 06, 2011 | Sony XPLOD CDX-GT200 CD Player
When i turn on my indash dvd keenwood player it jus says standby and nothing works
Press the SRC button to turn unit on. The SRC button allows you to navigate between input sources,i.e. tuner, cd, aux, etc. Press and hold SRC button for second to turn unit off ( it will display standby).
Oct 08, 2010 | Kenwood KDC-MP205 CD Player
Can't get auxiliary to work on Pioneer Mosfet Head unit 50x4
you have to turn the AUX input on through the function menu which can be accessed by following these steps
1. with the unit on. press and hold the source button unitl the unit turns of (or goes into demo mode, which is fine)
2. depending on the model that you have, you will have to press and hold the
(volume button or the audio button), until a menu is displayed.
3 . toggle through until you find AUX 1 and AUX 2. i would turn them both on and see which one you have plugged into, then you can go back and turn the other off.
4. once you have change it to ON. press the source button to turn on. the aux option should now be in your source options.
5. also, while on AUX, you can go into the audio settings and turn up the SLA (sound level adjustment) to +4
hope this helps
Aug 26, 2009 | Pioneer 50W x 4 MOSFET Apple iPod...
Can't select satellite option when pressing source button.
The Sirius Tuner is separate from the AM/FM/CD, check the plugs between the two. If all is snug, pull the SIRIUS tuner and go to a JVC dealer that would have any deck w/sirius as an option and plug it in. If it sees it, it's more than likely a problem with your deck. My guess is it's a bad SIRIUS tuner. There have been LOTS!!! Good news is there easy to replace if bad, and there cheap! $45.00 from Crutchfield rebuilt.
May 22, 2009 | JVC KD-HDR30 CD Player
I can't figure out how to get the player into mp3 mode. There is the button that changes between CD and tuner, but that doesn't do it.
Here's what they don't tell you: AUX isn't automatically an option when you scroll through the SRC button. You have to turn it on. I know, I know...stupid. I had to contact Kenwood (the maker of the unit) directly to get an answer.
  • First, press the SRC button repeatedly until it displays STANDBY.
  • Then hold down the Menu button until MENU is displayed.
  • Next press up or down on the right control knob, to scroll up or down, until AUX OFF is displayed.
  • Next hold the right control knob to the left or right until Aux switches on.
  • Now just press the Menu button to exit.
  • AUX will now be an option when you scroll through the SRC button
May 11, 2009 | Kenwood KDC-MP2035 CD Player
MP3, IPOD, CD doesn't appear when I press "Source"
If you read your owner's maunal, page 26, the USB is designed for a flash drive (up to 4GB), not an Ipod.
If you would like to play your iPOD, purchase the IPC008 (Ipod Lead) and you're done!
Feb 24, 2009 | Eclipse CD1200 Car CD/ MP3 Player
My Aux-in wont work
did you turned aux function?
turn off your player by pressing and holding volume controler.
press and hold longer (~5 sec) it again to turn it on (you should see 'tuner' in the lcd).
push up arrow to select aux and right/left to turn it on.
now you can connect your ipod and select aux (as ussual switching between tuner/cd player/aux)
cheers :)
Aug 22, 2008 | Pioneer DEH-30MP CD Player
Not being able to access my aux input
Try putting the unit in standby via the "SRC" button FIRST..., then press the menu button and cycle through to the "AUX 1" option and activate this....then press menu button again. When the unit is next switched on, you should have an "AUX" option accessible via the "SRC" button which will cycle through all of the availale modes ....standby-tuner-cd-aux etc etc.
Sep 22, 2007 | Kenwood KDC-135 CD Player
Can't get into AUX source
Are you sure it is an AUX input? According to the Manufacturers Specs, the AUX, is an optional accessory. There is a Pre-Amp connection, which would be an output, hence causing the problem you are having. Best of Luck.
Sep 13, 2007 | Kenwood KDC-MP232 CD Player
Sony CDX-F7700 CD Player Logo
24 people viewed this question
Top Sony Car Audio Receivers Experts
Larry Stiles
Larry Stiles
xxxxxx xxx
Are you a Sony Car Audio Receiver Expert? Answer questions, earn points and help others
