Question about RCA D52W19 52" Rear Projection Television
My 52" RCA rear projection TV will not turn on. Why?
I've changed remotes and batteries in remote. It will not turn on from front on TV either.
  • ms spang Jan 26, 2009
    My 52" RCA rear projection TV will not turn on. It is 4 years old. Before it would make static noises and the screen would blink on then off (this happened about 1 month before it totally quit). I would wait a minute or so and try again, the TV would then turn on. Now it won't turn on at all, you can hear static and once in a while the screen will blink. Checked the remote, the front panel on/off switch will not work either.
  • RCA Master
  • 5,138 Answers
Check cp150 on the Deflection board its the first board to left on bottom. If cp150 is puffed up on top then it is bad so repalce cp114 and cp120 also cp150 2200uf 16v other 2 caps 220uf 35v.
Posted on Jan 03, 2009
My RCA 52" HDTV Rear Projection TV Model #MM52110JX1 will not turn on. Neither the remote, nor the front panel switch will turn on the TV. When you press the power button on the remote, the red indicator...
you must check the light indicator if how many times does it blink which tell the main problem or the error code of the tv. either the power supply doesn't work normally or the lamp need replacement.
Sep 23, 2013 | RCA D52W19 52" Rear Projection Television
I have an 1998 rca premiere and it keeps changing channels by itself and turning itself up
You need to change the picture-size by using the TV remote and or cable remote.
On the remote look for P-Size, Zoom, Sreen size or Ratio.
Nov 10, 2011 | RCA P52937 52" Rear Projection Television
RCA HDTV D52W20 menu button no longer works.
The front keyboard circuits will need replacement. You can get a new keyboard panel from
Jun 27, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W23 tv
Front Panel Board needs cleaning or replacing Call Encompass Parts 1-800-638-3328 and for just contact switches Call Mats 1-800-628-1118
Jan 18, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Won't Turn on
Check the batteries in the remote 1st. If that don't work, call a TV tech to replace the IR sensor in the TV
Jul 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52
the chances are you front keypad has malfunctioning i see this alot at the shop. if you can remove the front panel and remove the keypad cuircit board and turn it on with remote then it will definatly be the keyboard generally i suggest replaceing this cuircit l
Oct 26, 2008 | RCA D52W19 52" Rear Projection Television
on my rca projection, it let me access all of those functions under the menu button, right on the front of the tv
Oct 07, 2008 | RCA P52926 52" Rear Projection Television
Did you change your battery from the remote?
Dec 02, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Crazy menu, comes on periodically without using remote
believe it or noT: try replacing all of the switches on the control panel (((power button switch,menu button switch, etc...)))
Oct 27, 2006 | RCA HD52W56 52" Rear Projection HDTV
RCA D52W19 52" Rear Projection Television Logo
878 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
