I have a Minolta Maxxum HTsi plus 35mm camera and I was wanting to know if the lens are compatable with any of the digital cameras? Here is the lens I have: (Lense) Tamron AF ASPHERICAL LD (IF) 28-300mm 1:3.5-6.3 MACRO 1850 (Extra Lense 4 longer zoom) PROMASTER SPECTRUM 7 1.7X TELECONVERTER FOR MAXXUM Mx-AF (Flash) MINOLTA PROGRAM 5400 HS 1/8000 sec thanks, James
Minolta Maxxum lenses fit certain Sony digital cameras. Check this site as it depends on the specific model.
https://feltmagnet.com/photography/Digital-SLR-Cameras-and-Those-Film-Era-Lenses
Posted on Feb 21, 2018
SOURCE: Minolta Maxxum 7000 35mm SLR Camera not working
Dear Minolta friends,
I have recently bought a second hand Maxxum 7000 and a AF lens, but found the body not ocntrolling the aperture while shooting. I know 7000 has someting special. Is my problem is due to lens and body compatibility or actually the malfunction of the body. I am sure the AF lens is ok since i have tried it working with another minolta af body.
Can give me an advice?
Posted on Dec 12, 2007
SOURCE: maxxum 7000
The lithium button cell is only a memory backup for when the main power pack is off the camera. It allows the camera to retain the number of exposures, asa setting, etc. You problem may lie in the battery holder. The BH70 was prone to corrosion at the contacts and the pivot points where the part that holds the batteries to the side plate with the retaining screw. It is possible to remove the batteries from the holder, then carefully separate the two pieces by popping one end enough to allow the pivot pin to slide past the notch. Use a hard eraser to clean all of the metal points (pivot contacts and the springs and plate in the 4 cell holder.
Posted on Jan 27, 2008
SOURCE: Shutter Blades out on Minolta Maxxum 7000
It is possible to fit them back since they are flexible. It does require a gentle touch, with a lot of patience. I use angled tweezers for this task.
Replacement parts are no longer available. Used cameras can be found on ebay and the like.
Posted on Feb 13, 2008
SOURCE: minolta maxxum 300si 35mm camera battery
It takes either: Energizer 475 or Duracell 245........if camera still will not fire, your camera has a problem. www.flcamerarepair.com
Posted on Jun 29, 2008
Jan 18, 2014 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Aug 22, 2013 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Jun 15, 2011 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Jun 07, 2011 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Nov 15, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Jun 18, 2010 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Dec 03, 2008 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Feb 24, 2008 | Minolta Maxxum HTsi Plus 35mm SLR Camera
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
348 people viewed this question
