Question about Masterbuilt Master Barbecue 7 in 1 Smoker - M7P
Masterbuilt Model # SQPGD - Low flame
I have the above referenced BBQ and regardless of the position of the knob the flame is always very low. Is this a problem with the regulator? Can someone please help me figure out the problem.
SOURCE: Brinkmann BBQ
It sure sounds like it's blocked. Purchase a venturi tube cleaner (about $5) or try removing it and lightly tap on the ground to try and unplug the little holes that have filled with debris. If you have access to some air tools, try blowing it out-similar to an air filter of a car.
Posted on Jun 24, 2008
meBNme
  • 334 Answers
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
You can buy a gas pressure guage from any HVAC supply house, and possibly at a gas utility office or the retailer that sold the grill.
It taps into the manifold, or gas valve.
For most LP systems you are looking for 11 to 14 PSI but double check with your system. You may can find it on the owners manual or on the data sticker.
Be shure to shut off the gas before you remove the plug and hook up the guage. Most plugs are either allen wrench or square head plugs.
Posted on Dec 06, 2008
  • 31 Answers
SOURCE: I bought a small used stainless steel Masterbuilt
http://www.masterbuilt.com/manuals.aspx
Posted on Apr 19, 2009
  • 10865 Answers
SOURCE: BBQ LOW FLAME WHEN ON
Your frustration is common because the new tanks all have a safety feature built into them which is a pain in the you know what. Unscrew the tank to reset the safety valve and then screw it in again. That should result in the valve being in the open position and working for you.
Posted on Jun 02, 2009
  • 11 Answers
SOURCE: Inefficient high pressure cast iron propane burner
Make sure you are using an adjustible high pressure regulator. Make sure there are no obstructions insde the burner tube or burner holes.
Posted on Nov 02, 2009
Do i put my wood chips on the flame disk bowl
I soak wood chips then put em in the pan above the burner on very low flame:
Sep 11, 2011 | Masterbuilt 20050106 Propane Smoker
The oval burner has only very low flame, even when set on high
Every one of these ranges that I have seen with the oval style burner on them have a smaller flame then the normal round burners. And there is very little difference between the low and high settings. It sounds like what you are experiencing is normal. What the GE repairman was adjusting is called the "simmer stop". There is a small flat head screw inside the burner stem. By turning this screw you can adjust the size of the burner on the low position of the burner knob. This should be adjusted to where the burner still stays on when the knob is at the lowest setting. I do not think that you need the burner repaired. From my experience they are all like that.
Mar 10, 2010 | GE Cafe CGS980S Kitchen Range
The difference between the flame bowl and water bowl
You want the wood chips above the heat source and then the liquid above that. The heat source smolders the wood whilst the liquid keeps the meat moist. Remember you want a very low heat.
Dec 31, 2009 | Masterbuilt 20050106 Propane Smoker
New electric smoker no instructions!
Put some water soaked hickory chips and some liquid smoke with chicken stock or pinot grigio wine or both in the pan above the heater element. Put yer rubbed and marinated meat in top above the wood mix. Plug it in. Pop a top on a cold brew of yer choice. :D The idea here is low and slow. You want the meat to be at or around 200 and the smoke to flavor the meat. This ain't no grill in 30 and eat, it is a low and slow smoker. It takes all night or day to cook stuff correctly. Low and slow my nizzle :D Party on! What time do we eat? Saturday? You betta get started. LOL
Jun 25, 2009 | Masterbuilt 20070106 Electric Smoker
BBQ LOW FLAME WHEN ON HIGH HAVE NEW TANK ON IT CHANGE HOSE GOING FROM TANK TO BBQ HAD TANK CHEAKED FOR LEAKS OK TRIED OTHER TANK STILL HAVE PROBLEM. CAN YOU HELP ME IAM MUST FRUSTRATED I have a grill whose...
Jun 02, 2009 | Char-Broil CharBroil 4637318 Grill
BO696 problems-burners too high on lowest position (propane used)
Remove knob, with flashlight look down top of shaft see a slotted screw that screw is flame adjustment.
To adjust, light burner, turn flame to low, with screwdriver turn screw rite till flame is at desired hight (aprox 2mm). now turn up to high check that high is satisfactory if high is to low then adjust screw. check low again. adjust till both setings are acceptible.
do for all burners
Feb 28, 2009 | Explorer Appliances BO696 Gas Kitchen...
do for all burners
As for holding the knobs that is common with this stove, you could check to see if flame is hitting sensor the burner hole that lines up the sensor may be dirty.
Masterbuilt Master Barbecue 7 in 1 Smoker - M7P Logo
352 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
