Question about Philips GOGEAR SA6045 MP3 Player
NEED URGERNT HELP!!!
Do you have any information or can forward me onto someone who can tell me how to change power supply on a Philips TV 29PT4873/79R?
Or do you have the manual
Philips 24pfl5505 service menu
Posted on Oct 23, 2011
  • 10,594 Answers
Hey mate,
Let me know chassis number of TV as model number is not so helpful to me in Philips service manuals.
I do have few service manuals of Philips according to chassis numbers.
I can refer you a website where you can buy service manual with model number. Philips model and chassis game is still Puzzle for me.
Posted on Dec 30, 2008
No picture only sound.
Engineers are right, you need a new LED panel., or the component that supplies the light to the screen.
Mar 18, 2016 | Philips 55pfl4706df7 4000 Series Lcd...
Need help for Philips tv
Get into its SDM mode. There is option to change the language. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 11, 2013 | Philips Televison & Video
It started to just click for several minutes when you try to turn it on before it would finally come on....Then it started to make that same clicking noise in the middle of the night even when no one was...
Tv power supply board it is causes and the problems.That the board where the tv power a/c cord plug into it.Take the tv aparts,check the tv power supply board carefully for dying and leaking capacitors components parts.These dying and leaking capacitors components parts are alway bulges ups or puffing ups onto it tops.U have all the tools and know basic electronic?Yes,than u must changes all these dying and leakages capacitors components parts are bulges ups or puffing ups onto it tops.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish tv power supply board for the replacement.As soon as the tv have a stable power supply board is it alway supply correctly voltages and current to the tv.These clicking noises will stops as tv turn on or the tv putting on standy power.
Aug 20, 2011 | Philips 50PFP5332D 50 in. Plasma...
Philips model no 29pt8319/57r
Can you tell me some more then "power supply fault". I need some more information ...
Feb 23, 2010 | Philips Televison & Video
Magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
Jan 29, 2009 | Philips 32MF231D Television
NEED URGENT HELP
I suggest you get yourself a service manual for the set.
Dec 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 32PW6506/1
there's a lose connection on your tv, if you know how to solder you can fix the problem, start with power supply.
Oct 09, 2008 | Philips 32PW6506 32" TV
Aura around the edges.
First disconnect power and remove rear cover look to see if any dust has settled on tubes. I think on that model you can remove screen frame by removing speaker grill, remove a few screws and then pullin forward on screen frame. Then screen w/ brackets will slide forward exposing tubes and mirror. This will allow you to look down in tubes with power on and see if any debris has grown in coolant chamber. This will tell you if you need coolant replaced, or if you need adjustments and/or circuit board work. Do not try to do adjustments if tubes are cloudy. Just have coolant replaced and the set will look like new. Good luck, Russmann.
Jul 28, 2008 | Philips 51PW9303 51" Rear Projection...
Philips tv
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
Jul 14, 2008 | Philips 21PT4475 TV
Tv comes on and goes right back off
High Voltage shutdown. Short in hv section or power supply
Feb 09, 2007 | Philips 43PP9202 43" Rear Projection...
Philips GOGEAR SA6045 MP3 Player Logo
347 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
