Question about Canon PIXMA iP1600 Printer
I have a Canon PIXMA IP1600 printer.
When I want to print, it pulls the paper to the left side of the printer (the opposite side of the light) and the paper jams.
  • 1,800 Answers
Reinstall driverers.
Posted on Dec 30, 2008
Printing blank pages
Hi Wendy,
This is known issue with Canon printers. Try the steps below.
Instructions
    • 1
      Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    • 2
      Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
      • 3
        Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
      • 4
        Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
      • 5
        Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Regards,
    Suhail
    May 20, 2012 | Canon PIXMA iP1600 Printer
    Will not print paper jam light comes on
    if the printer take in one side of the paper and then stop or jam, then most probably something, small item was caught or trapped in between the roller or wheel
    Feb 23, 2012 | Canon PIXMA iP1600 Printer
    Paper unable to feed
    All the Best..
    Nov 27, 2010 | Canon PIXMA MP470 All-in-One Printer
    How do you fix a paper feed problem in a Cannon iP1600
    1. Remove all of the paper from the paper tray and slide the paper guides all the way to the side. Examine the paper for any crumpled or torn pieces, then reload the tray. Make sure the guides fit snugly against the sides of the paper. If the guides are too loose, the paper can feed into the iP1600 skewed and cause a paper jam. If the guides are too tight it can cause the printer to grab more than one piece of paper.
    2. Open the front of the printer and wait for the print cartridges to move to the center. Do not move the cartridges by hand--this could damage the printer and void your warranty.
    3. Pull the cartridges slightly toward you and lift them free of the printer. Set the cartridges aside.
    4. Wipe the interior of the printer with a soft cloth to remove any ink residue and paper dust. The Pixma iP1600 has a tendency to accumulate a lot of paper dust, especially during periods of heavy use. Cleaning the printer periodically is the best way to avoid problems.
    5. Dip a cotton swab in warm water and carefully clean the bottom of each print cartridge. The print cartridges in the iP1600 printer also tend to accumulate paper dust. In addition the print nozzles can become clogged with ink residue, resulting in poor print quality and shortening the life of the cartridges. Continue wiping the cartridges until all ink residue and paper dust have been removed.
    Good Luck!
    Aug 23, 2010 | Canon PIXMA iP1600 Printer
    Canon iP 1600 printer won't print. Says that
    Hi
    If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
    Feb 01, 2010 | Canon PIXMA iP1600 Printer
    I have a flashing orange light, flashing three times then the power light(green)blinks once, before the three flashes of orange again. I know this indicates a paper jam, but there is no jam. How do I...
    You can't reset except by removing paper scraps. Try using an index card and gently push it backwards thru the rollers where the paper comes out to be printed. There are gears on the left side you can rotate to push the card to remove scraps.
    Jul 02, 2009 | Canon PIXMA iP1600 Printer
    Canon Pixma iP1600 Printer problem
    sure..disconnect printer from computer and then try a test page from printer stand alone
    Aug 19, 2008 | Canon PIXMA iP1600 Printer
    Part that holds paper up
    Sorry not the store.. just advice...
    Go to the manufacturers web site and ask them
    Apr 08, 2008 | Canon PIXMA iP1600 Printer
    Canon ip 1600 printer pulling on one side
    i need driver for canon ip1600 mac os 9.2
    Feb 22, 2008 | Canon PIXMA iP1600 Printer
    'Paper jam msg' when there's nothing stuck in there...???
    Sorry can't help. Maybe you have damaged one of the paper jam sensors?
    Try the link below which is the manual
    http://alpha03.c-wss.com/inc/ApplServlet?SV=WWUCA900
    Dec 29, 2007 | Canon PIXMA iP1600 Printer
    Canon PIXMA iP1600 Printer Logo
    76 people viewed this question
    old marine
    old marine
