Question about Pentax ME Super 35mm SLR Camera
Pentax ME The back of the camera has stopped locking securely when film is loaded. I can't see any apparent defects but the problem is consistent. Without film in the back closes securely and is opened in the usual way. With film loaded the back does not click fully into place and can be pulled open. Result - light sneaks in around the edge of the door, even when in the protective holder. Thanks
A simple fix might be to borrow a page from movie cameramen. Tape it shut with some black hockey tape. I was considering doing this eventhough my ME Super works fine. If you think that looks too getto, then it sounds like a service repair shop is the other answer.
Posted on Aug 18, 2007
Why is my camera flasing E when I load a new film
Usually it's because the film was loaded improperly. Another cause is a plastic spur gear responsible for moving the film is stripped, that would require repair at a camera shop.
Nov 30, 2014 | Pentax MZ-30 Film Camera
How do I open the back of a honerwell pentax-spotmatic camera to load film
Try lifting up the film rewind knob and pull the back cover. Maybe the back cover is stuck with the old gummy light shield.
Apr 25, 2010 | Pentax Photography
Camera repairs
loading mechanism,gear system must be defective,so u r not able to load the film,while loading shutter gets charged,stops running,so the shutter mechnism also be chaqued.
Mar 06, 2010 | Pentax SF1n 35mm SLR Camera
Pentax ME wider II problem
It should stop advancing the film when the camera counter is on #1 exposure with or without film.
Dec 08, 2009 | Pentax ME Super 35mm SLR Camera
CAMERA EATS FILM
When loading film, pull it all the way to the receiving spool.
Jun 16, 2009 | Pentax ZX-7 35mm SLR Camera
Pentax mz 60 unable to load film error message
error messages are for camera repair technicians and are found in repair manuals. have your camera checked by a camera repair shop tech.i would get an estimate first.
Dec 15, 2008 | Pentax MZ-60 QD 35mm SLR Camera
Loading film in my vintage camera..help!
The "magic needles" while making the camera easy to load are about as intuitive as a dead skunk, I had a similar confusion when I got an ME Super. Put the film can in the left side of the camera back (the side with the little thing sticking out is the bottom, it looks upside down this way, but that is correct). Next push the film winder down, this will semi-lock the can into place. Now pull the film-lead across the camera and push it down between some of the white "magic needles on the opposite spool(push it in a bit so that it will stay). Next advance the lever; release the shutter. If the spool starts to turn you are doing it right. Now close the door and continue advancing and clicking until the little frame number window on top reads 1.
May 19, 2008 | Pentax ME Super 35mm SLR Camera
Manual Rewind Pentax PZ
Hi Joel,
If your battery is dead, just put in a new battery.
Go into somewhere that is completely dark and open the back of the camera and remove the film.
Or go Costco, WalMart and Kmart and they will do it for free.
Dec 13, 2007 | Pentax ME Super 35mm SLR Camera
Film not advancing fully
Are you sure that you have loaded the film properly?
Sometimes if you have not started the film so that the sprocket pulls the film correctly the film can aquire slack and the teeth of the sprocket may not be successfully pulling the film from the canister each time.
Sep 07, 2007 | Pentax ZX-50 35mm SLR Camera
Pentax
i think it means the film hasn't loaded properly. I had this and opened up the back and the film hadn't wound so it wasn't exposed. Anyway i just wound the film around a bit and shut the back and it turned on like normal. hope this helps.
Jun 30, 2007 | Pentax IQ Zoom 60S 35mm Point and Shoot...
Pentax ME Super 35mm SLR Camera Logo
76 people viewed this question
Top Pentax Photography Experts
pontelemon
pontelemon
Bill Eager
Are you a Pentax Photography Expert? Answer questions, earn points and help others
