Question about HP Pavilion dv4000 Notebook
Left mouse button on touch pad not working
HP Pavilion dv 5000. Left mouse button on touch pad is not working. HP says it'll fix it for $298 and that the part is not user-replaceable. Really?
  • poop_shrute Apr 16, 2009
    Same stupid problem. The entire touchpad is screwed up. Lousy hardware. I'm looking at schematics to see if I can take it apart and see underneath the thing. I suspect the left button doesn't work because it's not making electrical contact.
    Replacing drivers did diddly - in fact it got worse, the damn computer did NOT find the mouse pad and I had to go to Synaptics, find the drivers, and manually install the suckers.
  • 1,800 Answers
Have u tried to check it on the control panel/mouse options.
if its not working though i guess the have reason about that.
Posted on Dec 30, 2008
Samsung laptop mouse left button
-If me I'll buy a new mouse.
Good luck
Mai
Jun 16, 2017 | Computers & Internet
Touch pad and external mouse not working
did you spill anything on it? it seems that it is shorted by some liquid. you have to take ity apart and dry it up. use a solvent or aclohol then a hair drier to make sure no water resedue is left in it
Nov 21, 2013 | HP NB199UA Pavilion Notebook
The right side of my touch pad control button has stopped working
Did you check the settings for the left and right buttons under the mouse properties. Normally the left should be set on Click and the right should be set on Shortcut. If it's set to NONE then it will be inoperable. Better yet you can click the Default tab for buttons. Otherwise, it sounds like your touch pad needs to be replaced. The immediate remedy to this is to just go purchase a USB mouse and voila, you'll have the ability to left and right click.
Mar 20, 2012 | Toshiba Satellite A205-S4617 Notebook
My mouse vertical scroll not working. my laptop model HP-Pavilion dv 5
Download and install touch pad driver from hp website probably your touch pad driver is Synaptics.
Aug 27, 2011 | HP Pavilion dv5000t Notebook
My mouse is frozen on my hp dm4 and the orange light in the left hand corner is not on, nor will it turn on when double tapped
First thought is look at the top of the touch pad, there is a button. Push this button once and see if the mouse works. HP put this button on to deactivate the mouse if needed.
If this does not work, plug in an external mouse and see if it works, if not do a hard boot on the computer and try the mouse again.
Jul 20, 2011 | HP Pavilion dv6000z Notebook
The left button below my mouse pad is not working on hp pavilion
blkcooper
Give Hp a shout.. and they will send you one. when you get it, come back onlie and I do a step X Step procedure for you
Jul 22, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
Touch pad not working nor mouse buttons
touch pad driver is download is your laptop.
see site and download your laptop touchpad driver
http://driversdownloadsfree.com/get.php
download mirror ok
Feb 25, 2010 | HP Compaq nx5000 Notebook
Hp pavilion dv4 left buttom not work
left click is membran switch it was fix in motherboard
need to replace it .
for tapping control you can set as per your comfort from
start menu ---> setting ---> control panel ---->mouse
in "Buttons" tab select double click speed and check it right side yellow folder open and close when you tapping
Feb 01, 2010 | HP Pavilion dv4000 Notebook
How to repair the left click button on HP Pavilion ZT1135
Hey,
I had the same problem. It is pretty easy to fix. You have one of two options to follow.
1) Push down moderately hard on the left mouse button. After 2 mins or so, and the cap should back on to the button on the bottom
2) if number 1 doesn't work get a needle or pin and lift the left mouse button off. Then just apply very little, not even a drop, maybe half of a drop to the button and apply the cap back on and push down.
Sep 25, 2009 | HP Pavilion zt1135 Notebook
Loose left button mouse on an hp dv4-1120us
If only the one button is loose then touch pad assembly probably will require replacement. This isn't a big job but usually involves opening the case. Two screws and one connector and button it back up. If the laptop is new you should have this covered by warranty. Cost of the part should be about $30-$70 as well as labor.
If you are lucky you might just have a loose fitting button that you can snap back in to place. With the laptop off try to gently push/wiggle the button down. It might pop back into its mounts. If this works (slight chance) then it might work normally for a while and pop out again. It won't have fixed the wear that let it come loose.
Aug 17, 2009 | HP Pavilion DV4-1120US Laptop
HP Pavilion dv4000 Notebook Logo
1,327 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
