Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Rinse cycle doesnt work
My washer will fill up at the beginning of the cycle but when it gets to the rinse cycle it just makes a humming noise and wont rinse. If I move it to the spin cycle it starts working again. This is on all cycles, and the cold water doesnt work at all either.
  • Anonymous Feb 05, 2008
    I have the exact same problem. the hot and cold taps are turned on. so its gotta be something else... HELP!!!
  • Anonymous Mar 28, 2014
    it gets to rinse the water just keeps running but never fills up, you to a new cycle on rinse and it works
    President:
  • 1,462 Answers
The humming noise is probably the cold valve operating but no water. check tap not turned off. slowly loosen cold water feed and check if water present
Posted on May 02, 2007
Washer only fills in the rinse cycle
This is a common problem with a double water input hot and cold. Theres 2 valves on the back that let the water in, the rinse works as it lets cold water in, this means your other valve is not working, the `hum` you can hear is valve trying to open as it is an electric coil actuator. Its an easy fix and the valves are quite cheap, theres normally only 2 wires, make a note of where they go, they are colour coded.
May 11, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore washer model 12502100 goes into rinse cycle fills with water turns then stops. won't drain just stops hear humming or buzzing noise.
Try to put it on rinse on another cycle, like normal, heavy duty or delicate. If it works, then your timer is probably bad. If it doesn't work then maybe the pump. Best of luck
Mar 21, 2010 | Washing Machines
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Machine stops at rinse cycle and hums
check the setting of the water temp for the rinse cycle. If one of your water supply valves is closed (HOT/COLD) the tub cannot fill with the proper water temp selected. The hum noise you are reporting is associated with the fill solenoid valve located in back of the machine.
Also, I have found the problem to be the screen located in the fill valve clogged with rust and water deposites. Disconnect both water lines and verify the water supply is not restricted.
Hope this helps..
If not, a more thural description of the problem may reveal more clues to assist in troubleshooting.
Thanks and good luck...
Apr 26, 2009 | General Electric Clothes Washer Timer -...
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer fills slow only in the rinse cycle
Need a model # to get exact part you will need at rinse most washer go straight cold so I would say water inlet valve if humming sound is present
Apr 28, 2017 | GE WBSR3140DW Top Load Washer
Rinse cycle problems
ckd cold water inlet may be full of sand ..most washers have a cold only rinse and will not advance to rinse unless fills with water..if good water flow to cold water inlet but still won't let water in suspect inlet valve
Sep 03, 2008 | Kenmore 98702 Stacked Washer/Dryer
Washer hums on rinse cycle
It sounds as if you are using WARM water for the wash cycle since your complaint begins with the rinse cycle. The rinse cycle generally uses COLD water, so I must deduce that your washer is not filling up for the rinse cycle. The humming sound is likely coming from the fill valve being starved for cold water.
Investigate your cold water supply to the washer and if you have good supply, you may want to replace the fill valve.
Let me know what you find...Thanks for contacting FIXYA.com
May 27, 2008 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
My washer washes, but doesnt rinse...
I sounds like it needs a new timer.
Oct 08, 2007 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
680 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
