Question about GE Spacemaker JVM1640SJ Microwave Oven
I have an JVM 1630,31 it stopped working after a power outage the house got cold and I turned the stovetop on for 5 minutes did I burn something out or was it because of the power outage? I replaced the fuse and still have nothing no power at all. I know there is power going to it because i ran a light to the outlet. please help if you can.
    President:
  • 2,692 Answers
Below refers to the manuals which all contain the wiring diagram.
Microwaves:
 Inside the actual case. It is not consumer accessible. Over-the-range models have the manual behind the grille or control panel.
http://www.geappliances.com/service_and_support/faqs/
Posted on Dec 31, 2008
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
JennAir Microwave works perfectly but won't quit running.
One or two of the micro switches have failed, you will need a professional to remedy the situation.
Apr 03, 2012 | Jenn-Air Microwave Ovens
I have a GE Over the range Microwave oven, Model JVM 1540DN. It will not stop running, doesn't seem to be heating up and turntable doesn't turn. When I shut door, it turns on and won't go off. Any...
Probably a bad door switch or mount.
See
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
http://207.234.249.73/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Dec 07, 2010 | GE Microwave Ovens
Micro GE Spacemaker XL1400 Sunday I was warming up soup for three minutes when ready open door and I heard a click, micro shut down I tested the power outlet with the blender and It work An hour later the...
IF YOU SMELLED BURNING TAHTS BAD, IT SOUNDS LIKE YOUR MAG TUBE WENT OUT (ITS WHAT MAKES THE MICROWAVES) iT WILL BE CHEAPER TO REPLACE IT, NEW UNIT STARTING FROM $115 FOR THE SAME MODEL
Jun 07, 2010 | GE Microwave Ovens
After a power outage in the house the microwave went dead. There is no display. When you open the door the light turns on and the fan turns on. I opened it up and the fuse is o.k. I noticed that there is a...
Usually if there was enough power to burn the traces then it usually will damage a few things. It's worth a try to fix the trace. If it works don't be too surprised if it fails later on.
Apr 28, 2010 | Panasonic NN-S762 Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Profile XL 1800 Microwave overheating?
ge spacemaker XL1800 (JVM 1870BF02) doesn't heat, lights, turntable works.
Mar 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Sharp R-1500 range lights
Are any other bulbs in the home going out prematurely? If so, I would check the actual voltage of your power outlets. If not, the bulbs may be getting grease or debris on them from stovetop cooking. This can cause hot psots and premature failure. I recommend wiping them clean with alcohol on a cloth before installing them. I recommend that folks always have their hood fan on when cooking on the stovetop. Also, you might check with a local home center (Lowe's, Home Depot, etc.) to see if they have some high-quality (non-Chinese) substitutes.
Aug 08, 2007 | Sharp R-1500 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
150 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
