Question about Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher
I have a 5 year old whirlpool gold dishwasher. The top shelf dishes are not coming clean. They do not come clean after purposely leaving the bottom rack empty. Is it possible the rotating arm under the top rack is not going around?
  • 1 more comment
  • scott or liz Dec 31, 2008
    Our dishwasher is not cleaning the top rack either. Thank you for notifying us when solution is offered.
  • wjlt Jan 13, 2009
    My dishwasher is having same problem. It is about a 3-4 year old whirlpool gold. I am very frustrated
  • pbattles Mar 29, 2009
    My Whirlpool dishwasher has the same problem and is a little over a year old. Repairman said it was too caused by soap build up and recommended a product that is used to clear up thebuild up. I've done that twice and switched soap products and reduce the amount of soap I use. Still have the same problem.
  • 78 Answers
Lift off the rotating arm,and soak it in lime away, or crc. It's probaly has lime deposits,keeping the pressure down
Posted on Dec 30, 2008
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Top shelf dishes aren't getting clean in my 5 year old Whirlpool dishwasher. Any suggestions?
The most likely reason the dishes in the uppper rack of your dishawasher are not getting clean is because the filter on the pump is built up withe debris and the water is havinga tough time circulating through the pump. This tip i wrote will show ya how to clean that filter.
Sep 18, 2011 | Whirlpool Dishwashers
My whirlpool gold dishwasher is about 11 years old now and is'nt cleaning my dishes at all...they are still dirty both top and bottom. Any ideas??
Make sure the water sprayers are not clogged. It may just be a good idea to get new sprayers and they are easy to install.
Aug 16, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
My dishwasher doesn't clean my dishes anymore and sometimes it doesnt dry them. it is a quiet partner 1 and it is about 2 years old.
It sounds like the water pump on the dish washer has gone out. A dish washer works (much like a clothes washer) by filling up the washer with a set amount of water, then through circulation, pumps the water up through the various spray nozzels. If the water pump is worn and not making enough pressure, the spray won't get the job done. Depending upon make/model, it may be cheaper to replace the water pump.
Run an empty dishwasher load with a bowl of white vinegar on the bottom shelf. As the dishwasher runs the cycle, the vinegar is slowly disbursed and cleans the dishwasher.
Mar 02, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
My dishwasher is not cleaning the dishes properly it leaves food on some of them. Is it gettin enought water? what could the problem be if not. It is 1 1/2 years old. thanks MAB
If the dishes are spotty or cloudy the problem is hard water. Go to They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 19, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The dishes on the top shelf does not seem to get clean. Does not appear water is coming out of the top spinning module.
Take out the top spinner and clean it thoroughly with descaler and degreaser / very hot soapy water. Soak it for a while and it will work wonders. Put it back in the machine and it will work like new.
Sep 10, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool Gold dishwasher
  1. not enough water gets into the dishwasher. check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
Good luck,
First Choice Appliance
Mar 21, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
Whirlpool Gold quiet partner III, leaves dirty, greasy dishes
Replacement parts for this type of dishwasher can be found on amazon. here: Amazon com Whirlpool Gold quiet partner III parts (You can ask sellers for particular problem, they know the best.) I hope this was helpful. Cheers
May 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool dishwasher is only 2 years old and I started having the same problems. I dismantled everything I could and washed and scrubbed the entire unit with no avail, dirty dishes!! But I discovered a remedy! Try using Lemi-Shine for about a week with your regular wash-soap. If you are using the tablet form of soap, stop and try the powdered form. Follow the instructions on the Lemi-Shine container. You can find it just about anywhere for around $3.50. I was within "5 seconds" of replacing my 2 year old Whirlpool dishwasher when this caught my eye and I figured why not try it too? After the first wash I noticed a big difference the cleanliness of the dishes..and now it is running GREAT after 2 weeks!
Sep 22, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Gold 24 in. Built-In Dishwasher Dishwasher Logo
508 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
