Computers & Internet Logo
Posted on Oct 10, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to purchase a replacement ribbon for my dell inspiron 1564 I am looking for the ribbon that goes from the power button to the computer all I can get as a decription is P-TWO AWM 20696 E221612-S. Does anyone know how I can get one?
joecoolvette
Level 3:
  • Master 5,660 Answers
  • Posted on Oct 10, 2012
joecoolvette
Master
Level 3:
Answers
5660
Questions
0
Helped
2192964
Points
18014
5 Related Answers
Anonymous
  • 114 Answers
  • Posted on Jan 17, 2009
SOURCE: Replacement adapter will not charge battery
Did the old one do the same thing? If true, your battery sounds like it is dead.
Anonymous
  • 1073 Answers
  • Posted on Mar 12, 2009
SOURCE: Dell inspiron 6000 power supply shot...
You welcome M8!
I hope it wont be to expensive to fix so you can get your laptob back alive again:)
Nic
Anonymous
  • 194 Answers
  • Posted on Jan 28, 2010
SOURCE: dell inspiron 1564 xp problem
There is a firmware update listed for January 10, 2010 on the Dell website. I would recommend punching your Dell Service tag into the driver and support section of the website and downloading/installing the bios update. If this does not resolve your issue comment back and we will move further.
Good Luck,
NOLA Tech
Anonymous
  • 151 Answers
  • Posted on Apr 28, 2010
SOURCE: laptop dell inspiron 1545 no power up
Hello anourkhader
When was the last time you used it, and were there any problems? To find the solution to this problem is a matter of elimination. You should check the following:
Step 1 - Power
- Try an alternative power adapter
- Try plugging in your laptop to an alternative power supply
WARNING - BEFORE PROCEEDING, PLEASE FOLLOW THE FOLLOWING SAFETY PRECAUTIONS!
1. REMOVE THE POWER ADAPTER FROM YOUR LAPTOP
2. REMOVE ALL PERIPHERALS
3. WEAR A WRIST-GROUNDING STRAP, AND CONNECT IT TO AN UNPAINTED, METAL SURFACE. IF ONE IS NOT AVAILABLE, TOUCH AN UNPAINTED METAL SURFACE TO DISCHARGE ANY STATIC FROM YOUR BODY
Step 2 - Remove and reset basic hardware items
Remove and reseat the items mentioned below in the order they're mentioned:
- AC adapter
- Battery
- Memory
- Hard drive
For instructions on how to do this, please refer to your user manual. If you no longer have it, you can download it from here: http://support.dell.com/support/edocs/systems/ins1545/
If after following the above instructions, your laptop still doesn't turn on, I would recommend that you contact Dell customer support, which you can do by following this link: http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
I hope this helps. Please feel free to contact me if you require further assistance.
ajblaj
cirocpatel
CIROC TECH SUPPORT
  • 524 Answers
  • Posted on May 03, 2010
SOURCE: i am unable to find the webcam driver for DELL Inspiron 1564
Click Here to download the drivers for webcam in you dell inspiron 1564
Please let me know if you have any further questions or concerns.
Thans.
How do you replace cmos battery on dell laptop 1564?
Go to Dell's support site: Product Support Dell US and click on the Service Manual pdf. Click on Coin-cell battery for step-by-step instructions and pictures. All Dell manuals are online.
Webcam softwear download
go to the site of Dell, choose Support, search for your model and os, all the drivers will be there.
1helpful
White screen at bootup
Dell Support > Inspiron1564 Notebook PC > Service Manual,
http://support.dell.com/support/edocs/systems/ins1564/en/sm/index.htm
http://www.insidemylaptop.com/replace-broken-screen-dell-inspiron-1564-laptop/
Let's start with two small primers first;
A) An LCD screen cannot produce light. It needs an additional light source. A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Dell Inspiron 1564 Notebook PC can come with either a CCFL backlight, or LED backlighting.
http://www.laptopscreen.com/English/model/Dell/INSPIRON~1564/
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[ Average thickness is 2mm. That is a little larger than 1/16th of an Inch.
Average length is almost as long, as the LCD screen is in height.
Basic example. Look at the last 9 photos,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/ ]
A screen Inverter is used to convert the electricity from the laptop, for the LCD screen, and Backlight.
For LED backlighting a screen Inverter may not be used.
B) For a Dell, video cable is Display Cable.
LCD screen = Display Panel
Switch Cover = Power Button Panel
(Cover that is a strip of plastic essentially, that is above the Keyboard, and below the LCD screen. Has Power On button)
Display Cable:
The display cable attaches to the motherboard, in an area under the Power Button Panel. (Above the F2 and F3 key, approximately)
It then routes under the left Hinge, and up into the Display Panel Assembly.
From there it attaches to the screen Inverter, if used, and to the back of the LCD screen.
A example of the cable,
http://www.ebay.com/itm/DELL-INSPIRON-1545-LCD-FLEX-CABLE-LED-R267J-NEW-/370491513861?pt=US_Laptop_Screens_LCD_Panels&hash=item564303dc05
The cable may become pinched in the left Hinge. This can cause pulling on the cable, and/or damage.
Pulling may cause loose connections of the cable. Loose at the motherboard side, or LCD screen side.
Doesn't take much of a loose connection to get issues like what you are seeing.
In fact it may be so minute (My-noot) that it won't be visually seen.
The ONLY way to be assured the connections are tight, is to PHYSICALLY check them. Try to plug them in tighter.
This means checking the display cable on the motherboard side, and LCD screen side.
http://support.dell.com/support/edocs/systems/ins1564/en/sm/powerpan.htm#wp1061007
The Power Button Panel contains the Power On button/switch.
It can be removed, and laid over so that the motherboard connection can be checked, with the Power On switch still attached. This way after physically checking the connection, the laptop can be turned on, and display checked.
[Lay the Display Panel Assembly back as far as you can. Suggest covering screen with soft cloth, or suitable device to protect screen.
Screen has to be handled as if it is good, until diagnoses shows differently.
If the Power Button Panel cannot be laid back far enough, to get out of your way, unplug the Power Button cable. Plug back in to check display.
ALL power removed BEFORE disassembly.
Replace Battery, and AC adapter (Charger) when going to test display, after checking connection ]
For the LCD screen (Display Panel) side of display cable connection,
remove ALL power, then,
,disassemble down to Step 7. This way you can lean the screen out, and check the connection.
Display Panel connection physically checked reinstall power, turn on, check display.
IF there is obvious visual signs of damage to the sheath of the Display Cable, there may also be damage to the tiny wires inside.
(Stretched/Broken)
A continuity check with a multimeter is warranted.
If the Display Cable's sheath does Not show obvious signs of damage, it is still best to perform a continuity check, so you can Positively rule out the Display Cable as the problem.
Suggest go to a local 'Mom and Pop' computer store, and for a coupla' bucks have them check it.
Or replace it.
Display cable checks out 5by? (OK)
Go on.
Screen Inverter:
The next item to check is the screen Inverter, IF a screen Inverter is used.
90 PERCENT OF THE TIME the fault can be attributed to a bad screen Inverter.
One example of an Inspiron screen Inverter,
http://www.ebay.com/itm/New-Genuine-Dell-Inspiron-1545-Series-Lcd-Inverter-Board-15-6-H251M-0H251M-/300756244730?pt=US_Laptop_Screens_LCD_Panels&hash=item46067818fa
Yes. It's an Inspiron 1545 screen Inverter. Couldn't find a listing for an Inspiron 1564 screen Inverter. Means to me that most of the 1564's use LED backlighting, or everyone is switching to an LCD screen that uses LED backlighting.
Display Panel:
If the screen Inverter checks out, the problem is the Display Panel.
(LCD screen)
IF there is No screen Inverter used, the problem is the Display Panel.
I'm willing to bet you have a loose Display Cable connection, or damage to the Display Cable.
For additional questions please post in a Comment.
Regards,
joecoolvette
[ For the areas you are going in no ESD wrist strap is needed.
It IS however, always a good practice to wear one, and have it's alligator clip attached to a good ground source.
Electro Static Discharge.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer. (Laptop or Desktop)
Doubtful that you will see it, or feel it. Poof! Your computer is fried.
An ESD wrist strap relieves your body of Static. You CANNOT just touch a metal frame of the laptop to relieve your body of Static, like you can a desktop computer.
Average cost is around $3 to $6. One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case. I do not feel an anti-static mat is warranted.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or use a large metal knickknack (Unpainted ]
1helpful
I have Dell inspiron 1564 (windows 7 64 bit). The monitor goes blank with a screeching noise. I have run the PSA diagnostics but it showed no problem. The laptop runs normally otherwise but this problems...
I now have the same problem with the same Dell model (1564) for the second time in less than a year from purchase. The last time it happened I called the service technician who fixed it. That makes me wonder if this may be a common defect in this dell model, which requires a technician visit every 4 months. I advise you to apply to the company and ask for solution such as providing you a different model as a substitute for the defective one.
I am using dell inspiron 1564 .now i cant even install a single game because of vga problem ... what shall i do now sir
As you are using dell inspiron 1564 it comes with a atleast 512mb graphics card by default. If you are not able to play games on it due to Vga problem first check you install the proper vga display drivers for the laptop or try to reinstall the vga display driver again from the drivers disk you get with the laptop. After installation of proper vga drivers all your games will work perfectly.
Dell 1564 web cam
Try opening My Computer on your Desktop if not you can access it in the Start or Microsoft Logo Orb. You should be able to see your Webcam icon there. For the meantime, please let me know what applications/Softwares installed in your computer.
3helpful
I am unable to find the webcam driver for DELL Inspiron 1564 compatible with Vista..... can anyone help plz.....
Thans.
I AM PURCHASED INSPIRON 1564 LAPTOP WITH DOS OS & WITHOUT WINDOWS OS. I DON'T RECEIVE ANY CD FOR WEBCAM. IT'S NOT THERE IN DELL 1564 DRIVER SITE. PLEASE HELP ME TO GET WINDOWS 7 32 BIT WEBCAM DRIVER ...
First of all, since you have no OS, you will need to purchase a copy from the computer store. Put the disk in the drive and boot the computer. As it's booting up press F2 and set to boot from CD. The Windows install shield will put the Windows OS onto your hard disk and install all the drivers for all conected devices, including the web cam.
Grand Canyon Tech
Grand Canyon Tech
