Question about Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117
The water hose keeps bursting while welding aluminum
  • Ron Jones
    Ron Jones May 11, 2010
    Which hose - on the torch on the the pump or another location ?
  • Robert Lee May 11, 2010
    does the pump run
    is water flowing back into the tank when the pump runs
  • 92 Answers
The probable caures is due to the coolant pressure, do'nt turn this full on, if it's from the mains tap turn on and notice a trickel from the outlet, one half turn of the tap should be ok depending on the water presure. If its from a recirculation tank check the vale govener inside the tank. The torch data will indicate the coolant pressure
Posted on Feb 27, 2009
What water do I need to use to weld aluminum
never heard of welding aluminum with water,but I would recommend using blue sheild gas or argon
Oct 04, 2014 | Welding Tools
My kreepy krauly hose is always getting twisted what can I do
ive had great luck with installing a piece of non rusting wire curled up like a spring inside 1st 3foot of hose and keeping floats on last 15 feet of hose
aluminum welding wire works a charm
Oct 04, 2014 | Universal Kreepy Krauly In-Ground Pool...
2002 bonneville coolant leak
check water pump hose and the pump. a clogged thermostat can cause pressure build up and bust hoses. and of course take radiator out and check for lower hoses and crackes. if no luck, put water in radiator and run car and check for leaks. small cracks in aluminum are hard to see but expands when radiator gets hot.
Jul 14, 2013 | Cars & Trucks
Trying find out what i would have to have to start TIG welding with a Miller Bobcat 250 1992 year model
you will need a AC high frequency unit to weld aluminum. For stainless and mild steel just need a dry run tig torch, hose kit and 100% argon.
Sep 11, 2011 | Welding Tools
The F 1 circuit breaker, manual reset is tripping not allowing it to weld. Could it be something as simple as the reset itself
Rated Output at 20% Duty Cycle 150 A at 16 VAC
150 A at 16 VDC Welding Amperage Ranges AC/DC 10 - 165A Max. Open-Circuit Voltage 80 V Amps Input at Rated Output AC-230V: 21A
DC-230V: 23A You need to configure the machine to specifications of the material you going to weld.That is :
-The material of the job
-And the proper amperage to use for the material.
-For aluminum you will use A/C
-Stainless Steele / Chrome Molly D/C
Aluminum MIG Welding
1. The best feeding of wire for aluminum is done with a spool gun. If you can't use a spool gun, use the shortest gun possible and keep the gun as straight as possible. Use Argon only for shielding gas. Only use a push gun technique when welding aluminum. 2. If you are having feeding problems, one thing you can try is a contact tip that is one size bigger than your wire. 3. The most common wire type is ER4043 for all-purpose work. ER5356 is a stiffer wire (easier to feed), and is used when more rigid, higher-strength weld properties are needed. 4. Clean the aluminum before welding, to remove the oxide layer. Use a stainless steel wire brush used only for cleaning aluminum. 5. Fill the crater at the end of the weld to avoid a crack. One way to do this is to dwell in the weld pool for a second at the end of the weld.
Nov 07, 2010 | Hobart Welders 500433 Champion? 10,000...
Upper hose from Radiator burst today shortly before or after arriving at work. Replaced with a new one but concerned hose is not real problem. aluminum housing on drivers side of upper hose extremely...
keep your eyes on the the temp when driving. sometimes the fan takes a little longer to come on.how bad is the anti=freeze.when was the last time you changed your hoses. every for to 6years hopefully.but be sure the fan does come on before it starts to over heat.
Sep 21, 2010 | 1988 Oldsmobile Cutlass Ciera
Oil pan has a crack in it, and I would rather not pay $250.00 to replace it
it will stay MG if it's mangesium and i would say no it's not that.
its most likly steal.
the steal is to thin to weld unless your very skilled.
aluminum is to soft and will melt.
MG will burst in flams and may blind you.
Don't weld this. just go to junker get a new one and guy a gasket from NAPA or someting. it will tkae 30 min to drain the oil take it off put the new one on and tighten it up with the gasket..... some were around 20ft/lbs should be fine. or just tight. start your car and inspect your work. if it leaks tighten it up more.
May 30, 2009 | 1996 Saab 900
Bottom part of the water pump on '95 Nissan Maxima broke.
You are going to need someone that is Really good Welding Aluminum as all the Import Blocks are Aluminum. Some good Mechanics can Weld this Back on Well enough to Use the Hole again for the Bolt. I would make some Calls and see if you cannot Find one. Please Rate My Response! Thanks!
Feb 02, 2009 | 1995 Nissan Maxima
Welding aluminum
TIG weding is next to brain surgery as far as CLEAN goes.
You must get your AL clean, either by 1. Clean with a NEW Stainless Steel brush or 2. by using a chemical from the welding house that is made just for that.
Your cup must be clean and your gas flowing at the right amount,no leaks in o-rings or hoses.
Hold your cup more vertical and keep your filler rod in the gas shield always,no in and out movement.
In short you must get everything perfect to get quality Heliarc Al welds.
Good luck, HowardRoark
Dec 22, 2008 | Miller Electric Manufacturing Electric...
Special water hose needed?
i dont know of of a"special hose". are we talking about water inlet (hot and cold) hoses??drain hose??? or a vent hose for dryer???
1. stainless steel non-bursting fill hoses are available in up to 6' lentgh's
2. drain hose can be extended if need be, i would make it as short of an extension as needed, and use a hose of atleast the existing diameter and make sure that it wont, bent or pinch off after putting into drain pipe
3. dryer venting should be a solid aluminum 4" pipe as shosrt as possible with least amount of elbows needed.
all available at a quaitly home improvemnet store/ hardware store
Oct 30, 2008 | LG WM-2277HW Front Load Washer
Miller SYNCROWAVE 250 DX TIG RUNNER WELDER 951117 Logo
254 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
