Question about Intertherm Heating & Cooling
The Motor THAT is located at the bottom of the exaust pipe continues to run when the furnace finishes to blow hot air . What is the cause? Thank-you Kirk
  • 1 more comment
  • kaadahewlett Dec 30, 2008
    INTERTHERM Gas Furnace Model # MGHB090AAPQ-1. The furnace has been working fine until recently. When the fan finishes blowing the hot air, the motor at the bottom of the exaust chimney stays running.
    Thank-You. How do I go about replacing the thermal sensor switch.
    Thank-you. It seems like my air filter may have been overdue to be replaced. This may have been causing wrong signals to go to the Thermal Sensor.
    Your solution was very helpful.
    Thank-You and a Happy New Year.
  • 177 Answers
Hello and welcome to FixYa!,
This problem is caused by a defective Heating Coil or ThermoStat Sensor, these may need to be replaced as they might have become defective or broken.
This might be the solution you are looking for - hope it is your FixYa!
--P3NGYJ03
Posted on Dec 30, 2008
    Sergeant:
  • 233 Answers
There should be a small thermal switch (heat sensing component) near the heating coil. If this switch is defective, the fan will stay running since it still "thinks" the coils are hot. Replace the thermal sensor, and it should be fine.
    Sergeant:
    Novelist:
  • 326 Answers
Some connections are crossed up still supplying a small amount of power to the motor.
  • technodeal Dec 30, 2008
    check the internal connections and u can repair the faulty connections
    also check thermal sensor and if its faulty replace it
My Lenox EL296uhv furnace quit running has error 227 & 228 code.
Your induction blower motor makes vacuum as it blows out the exhaust. these code are saying that there is no vacuum..It is probably caused by your exhaust being blocked by something. Maybe snow or ice build up due to cold temp. Try a hair dryer to heat up exhaust pvc pipe melt ice in pipe. CAREFULL do not get it so hot it melts.
Feb 15, 2015 | Heating & Cooling
Goodman GS9 blowing air but not getting hot
Does furnace fire up ,if not you have a issue with your furnace and not thermostat
Feb 12, 2018 | Goodman GMS90703BXA Heater
Heil furnace blower motor stays on won't shut off at thermostat blows cold air continuously
Do you have t sat fan switch in on position??? If so blower will run continously set it to auto and it will cycle with heat call
Nov 12, 2012 | Heating & Cooling
The blower on my Dayton furnace runs but there is no flame/ignition. Just blows unheated air. It continues to run regardless of whether the thermostat is calling for heat or not. Anyone have any ideas?
When the blower motor run all the time, that mean you have a safety limit tripped. One of the limit is located on top of the burner, to reset that all you have to do is press down on a little tap that sticking up in the middle of the switch. The second switch is located at the flute pipe, to reset the switch is the same procedure. The third limit switch is located on the heat exchanger box itself, this one cannot be reset, you will need an ohm meter to check for contunuity. Set meter to ohm function, if the meter read nothing then the switch is bad. Good luck.
Feb 02, 2011 | Dayton Gas Furnace Heater
Furnace will not blow hot or shut off
The furnace has a fault check the furnace compartment for a flash code and check it with the code chart on the furnace door. Turning the power off to the furnace and turning it back on will reset the fault but it may happen again till you verify the fault and fix it.
Feb 22, 2010 | Heating & Cooling
The floor vents in our house are blowing cold air instead of hot. What can we do to fix it? What would be causing this?
If the furnace is running and the registers are blowing cold air you have a problem with the furnace. Check to be sure the pilot lite is lite if this is a standing pilot, if not check to see if there is a flash code in the site hole in the bottom blower door of the furnace. Be sure the thermostat is set to heat and turned up.
Jan 02, 2010 | Heating & Cooling
Heat not coming on carrier gas pack code 31
code 31 indicates pressure switch did not close or reopened during the heat cycle....1st thing to check is the inducer motor,,this is a small motor that turns a small blower wheel that draws the exhaust gases through the furnace and blows them into the vent pipe....1st locate the inducer assembly,,most easily identified by the small plastic fan blade that cools the inducer motor as it runs..1st turn off tstat and turn off furnace power switch..then turn on furnace switch,then set tstat to heat,set the temp above room temp by 5 degrees...remove the furnace front cover,locate the inducer motor,,if it isnt turning,but is warm or hot after a minute or so,likely the inducer motor is bad..if it isnt turning and isnt warm after 1 minute,then likely the main control board is bad,,not turning the inducer motor when it should,,,,,if the inducer motor is running,,then the pressure switch isnt closing,, could be a bad pressure switch but more likely there is a problem with the venting...some possible problems that would cause the pressure switch not to close in an 80% eff furnace [metal vent pipe] are: [1] a blockage in the vent pipe,base of chimney,dead bird at the furnace where vent connects to furnace or down inside the inducer assy,accessed by removing vent pipe from furnace....if all clear the chimney could be blocked up inside,,is the draft good when vent is removed from base of chimney?..if furnace is a 90%+ type [pvc plastic vent pipe],,then check the intake pipe at the furnace by removing it where it attaches to top of furnace..is the intake clogged with anything?..then check the intake and exhaust pipes outside for blockages,,including ice/frost/snow at the exhaust pipe outlet..
Jan 26, 2009 | Goodman GMS90703BXA Heater
Furnace not blowing hot air
Check your flu pipe and make sure there is no obstruction in the entire pipe. Sometimes the exhaust fan for the flu will not come on because the safety will not allow it to and it will also cause the fan to run, but not the burners to engage ignition.
Hope that helps.
God Bless.
Erik
Aug 08, 2008 | Weather King 12AJA6001AH Air Conditioner
Heating & Cooling Logo
Top Intertherm Heating & Cooling Experts
Dennis Boxerman
Dan Webster
Dan Webster
Bill Long
Are you an Intertherm Heating and Cooling Expert? Answer questions, earn points and help others
