Question about Home
Gainsborough royale mixer shower only delivering cold water
Initially had ceased to work so dismantled ,cleaned filters etc. Probably put back incorrectly and so could use a diagram to get it right. It is driven by pump.
2 Suggested Answers
  • 3 Answers
SOURCE: i have a Gainsborough Royale Antique and i can not get cold water
how old is the shower?
Its a mixer, am I correct?
Posted on May 07, 2010
Mira 88 not supplying hot water
may have a screwed up washer seal on the hot side..it will stop the flow to a degree and allow more cold water in..calls for dismantling the entire control or replacing it..
Jan 26, 2014 | Water Heaters
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
Got a gainsborough shower no water is coming out when i switch it on and the low flow light in coming on
inside the shower unit theres water connection to unit ,turn the water and power supply off and check the water conn filter its on the connection comming into the shower its most prob blocked good luck
Feb 18, 2011 | Hardware & Accessories
Very little cold water, lots of hot from kohler shower valve
Probably some pipe rust clogged the exit.
If u have pretty low presure as default on both hot and col water, try keep force closed by hand the water exit at shower pipe, then start both cold and warm water gradually as much as u can keep it closed with the hand.
The hot water pressure going back thru the cold water pipe might unclog that debris.
Just a simple fix which many times works as a charm..
Otherwise if this is not fixing, try close both water from main service valve.
Then unscreew the secondary shower valves and manually clean them or replace if very damaged.
Dec 14, 2017 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Filter seems cloged
Have you tryed soaking it in viniger will clean shower heads.
Do you get a good stream of hot water through the shower arm with the shower head off. Take it off and make sure shower valve is suppling hot water.
Mar 06, 2010 | Water Pik & Wallmount Showerhead
Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Oct 08, 2008 | Home
Home Logo
733 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
