Question about ViewSonic VX924 19" LCD Monitor
Monitor flashes image for split second then goes blank but green LED flashes as well
I have had the ViewSonic VX924 for about 1.5 years. Just this morning when I moved the mouse to wake up the monitor, the screen flashed an image for a split second and then went blank. However, I noticed that the green LED flashes as well. I have plugged in other computers to the monitor and all display the same result. They work fine on a different monitor. I have read in the manual a working that too high a resolution and refresh rate can "permanently damage" the monitor. Any help appreciated.
  • 3 more comments
  • BigFatDaddy Dec 01, 2007
    Same Problem. I have a dual monitor setup (one 922 the other a 924). The 922 works fine with either cable through either display card port.
    If I press the number 2 button on the monitor the display shows the expected screen for about 1 sec then goes black again.
  • Anonymous Feb 07, 2008
    Same Problem with mine....I'd say about a year old.
  • Anonymous Feb 08, 2008
    vew sonic LCD monitor goes black. if the monitor is turned off and then the computer is turned off then the computer is turned on and allowed to fully boot. turn the monitor on and it works fine.
  • kboy999 Mar 18, 2008
    mine flashes on boot, I get the post beep and I know it boots but the led is just flashing green on the monitor. Changed cpu, mobo, & psu.
  • Robert Dyet Sep 15, 2008
    Hi I have VX924 monitor, when switched on the screen displays for about 1 second then goed black. Monitor green light stays solid. I have checked both DVI and D connector no diffrence. I am able to power pc down by multiple pressing on the screen enough times to power down thru mouse clicks. Greatful for any feedback thanks
While the monitor is still powered on, but with the LED flashing, unplug the monitor from the PC. press the power button, and the monitor should go off, now plug the pc back into the monitor. Turn the monitor back on and it should work.
Occasionally this will not work for me, but if I repeat it it normally works
Hope this helps - my problem is intermitant so it may be different to what u guys have
Posted on May 06, 2008
What I did with this problem:
since i have a nvidia card i went into the nvidia control panel and use the other monitor as a single monitor and then pushed apply after that i just set up dual monitor again and it worked and you dont have to reboot you system.
Posted on Sep 11, 2008
After the monitor has been turned off, along with my PC, if I turn on the monitor at the same time that I turn on the PC it will go black, with a slight flickering, and the power button flashes on and off. I can't even turn off the monitor when it's started to do that. I power off the PC to get the power light back on on the monitor and can then power it off.
However, if I don't turn on the monitor until XP has had time to get to the full resolution login screen, which I can tell by the hard disk activity light on the PC, then when I turn on the mon it works fine. And doesn't flicker. This means I can't get to see the pre-boot screens and it's most annoying.
Posted on Jan 29, 2008
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Monitor goes blank after 2-3 seconds
could be hardware failure but i would try buttons on front of monitor first. notice, usually green led on monitor is green, if it goes to amber, you are loosing sync pulse.
Aug 20, 2009 | Computers & Internet
Viewsonic Optiquest Q19 blanks out - just a year old
Sounds like the LCD panel inverter is going out, if not gone out completely.
Jul 18, 2009 | ViewSonic Optiquest Q19wb LCD Monitor
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Lg flatron blank screen
t certainly seems like the monitor is not getting a signal. Did this happen after you changed something, or just on normal boot up?
It could be the video card that has failed.
Also, check the pins on the connector; sometimes they can get pushed in.
If you can, try swapping out the video card or use the monitor on another computer.
Good luck,
May 09, 2009 | LG Flatron L1951S 19" LCD Flat Panel...
Viewsonic VA903b Flashing green light (slow)
Hi..there,
It's seems you got a busted backlight inverter problems... Need replaced with a new one. Happy Holidays!
Dec 03, 2008 | ViewSonic VA903B Monitor
have you checked the capasitors?,if they,re ok then the proublem is one of the transistors it will have the letters DKQA on it ,they control the backlight power
Nov 30, 2007 | Sceptre X9G Komodo IV 19" Flat Panel LCD...
ViewSonic Monitor has trouble to wake up after been shut down?
Ok sounds to me like a power supply problem.. this a a fairly common symptom. I suggest that as a temporary fix you set the monitor to NOT turn the power off to the monitor in sleep mode if possible, in your power settings for the monitor.
Jul 24, 2007 | ViewSonic VX924 19" LCD Monitor
My ViewConic Monitor has exactly the same problem as this another post? HELP!
Does it come back if you lower the resolution to the lowest and make sure the refresh rate is at 60 Hz?
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
ViewSonic VX924 19" LCD Monitor Logo
2,343 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
