I tried using the CMD, attribute command but it still remains corrupted which says "access denied or drive is corrupted".
Try using chkdsk /? It displays help.
Actual cmd would something like: chkdsk e: /f
Testimonial: "It worked thanks. "
Hi friend,
The only way you can access that USB flash drive
is by formatting it, but formatting the flash drive results in complete data
loss from the device. However luckily these lost data can be recovered back
with the help of a file recovery software. The one which I would like you to
use is Yodot File Recovery, which performs pen drive
recovery easily. Apart from pen drive the software also supports recovery
of files from all kinds of flash drive and other storage devices
Do not worry you can recover your lost files from corrupted USB flash drive by using USB drive data recovery software. When I faced the similar situation like you, I was able to recover files from corrupted USB flash drive by using this tool. I hope this tool will help you in this situation. You can also download the trial version and examine the recovery results prior to purchase the software. Good luck
SOURCE: USB Flash Drive
- Click Start / Run / diskmgmt.msc {OK}
- Right-click the memory card, then create a partition & format it.
SOURCE: I cannot access my flash
Maybe this can help .... http://www.online-tech-tips.com/computer-tips/usb-device-not-recognized/
insert 8 GB USB go to control panel administrive tools computer management disk mangement you you can right click select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files
hope this helps
Was indeed helpful.... which did recover half of my files.
Try opening the still corrupted files in Wordpad or Notepad. They may open with some data in tact. This is only for docs.
