Question about HTC Shadow Smartphone
My HTC Shadow won't turn on
I have the HTC Shadow and it won't turn on. I dropped it and the battery fell out and now it won't turn on or reset ro anything. I just need to know how to get it back on
  • Anonymous Mar 14, 2009
    The phone shows fily charged by the indicator but will not power on
    Problem Solver:
  • 7 Answers
Will the phone even indicate that it is taking a charge when it is plugged in?  If not, the phone is out of commission and then you will need to file a claim with Asurion if you have the Premium Handset Protection that they offer with most service providers.  The deductible would be about $110.00.  Or you could wait and just purchase the Shadow II on January 28th when T-Mobile releases it.  Good luck!
Posted on Jan 13, 2009
Honda VT 500 C Shadow will not turn over
Hi, Anonymous before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Bike won turn over
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
http://www.cycleterminal.com/Service-Manuals/Honda-VT500C-Shadow-Service-Manual-English.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vt-owners-manuals
May 23, 2014 | Honda VT 500 C Shadow Motorcycles
1984 Honda shadow 500 won't start.
1984 Honda Shadow VT500 Won start
Apr 21, 2013 | 1984 Honda VT 500 C Shadow
2005 Honda VT 750 Shadow Aero will not turn over
Hi, James before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
2000 Honda Shadow Ace 750 Wont Start Turn over at all
What to do When Your Motorcycle Won Start
Honda VT750C2 Shadow Spirit Service Manual
Honda VT750C2 Owner Manual
Jun 01, 2017 | 2005 Honda VT 750 Shadow Aero
HTC battery wont charge
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 04, 2011 | HTC Desire Cell Phone
Fully charged battery but wont turn on
HARD RESET
  1. Power the Shadow off
  2. Hold down the two soft buttons (The two right under the screen)
  3. While still holding the two soft buttons, turn on your device
  4. There should be a quick menu that pops up asking if you want to reset it. Say yes, let it reboot.
  5. It will then start restoring your phone to defaults
Mar 19, 2010 | HTC Shadow Smartphone
My HTC PDA 8125 fell in water. Got it out immediately but does not work. Will a new battery solve problem
no...but u can try.....but dont buy yet...OR u have to proceed to the nearest dealer to check the htc motherboard inside cos sometimes when our HTC fell into water it will wet in our HTC board....
either u can try to test with the new battery but BETTER proceed for formatting via usb with the expert
Nov 05, 2009 | Televison & Video
My HTC Shadow goes to the white Tmobile Shadow screen and gats stuck and wont go any further. I can't turn it off using the keys I have to take out the battery to turn it off
the "soft buttons are right below the screen hold both down then turn on the phone this will make the phone ask if you want to reset to default so try removing the batt , mem card and sim card first as this it the last resort you will lose all changes made to the phone except mem card and sim card stored items worked on my shadow fine good luck peeps
Aug 21, 2009 | HTC Shadow Smartphone
T-Mobile Shadow Water Damage
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Mar 08, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Tmobile shadow cellphone
Power the Shadow off. Hold down the two soft buttons (The two right under the screen) and turn it back on. There should be a quick menu that pops up asking if you want to reset it. Say yes, let it reboot, and it will then start restoring your phone to defaults.
You will loose all your data.
Jun 21, 2008 | HTC Shadow Smartphone
HTC Shadow Smartphone Logo
1,266 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
