Question about Brother MFC-5460CN All-In-One InkJet Printer
My Brother MFC-5460 says "print unable 50". how can i fix it?
When I tried to re-install the printer and do a "test print" my computer responded by saying my feeder might be jammed. So I checked my feeder and I saw nothing not even the tiniest piece of paper. I've also tried troubleshooting websites however no one had my problem so the answer was not available.I really really really need this printer to work. Can somebody PLEASE help me?!
  • duarte_famil Jan 26, 2009
    Mine also comes up 'Printer unable 30' & I cannot turn off machine via power button. Rebooting LAN didn"t work either. Aaaah!
Mix-it-up
  • 832 Answers
SOURCE: brother mfc 5460 cn Paper jam problem
thx infonet. Sorry for reading that you have another prob. Did you open the printer? In case yes, you might have disconnected the small plastic foil which leads the printhead (encoder strip). The foil is located paralell to the driving belt of the printhead. try to fix it in place again. Have a look at the foil (encoder strip): is it stained with ink? If yes you need a new encoder strip. If not you have to place the head on the leftside (where the three white disks are) You can pull the head up in that position and watch the encoder strip when pushing it back in place. Another reason could be that the head crashes somewhere on his cycling way: Open cover and press the two plastics by thumb (located on the other side of the arrow-knob facing to inside) to avoid : cover open message. Power up machine. watch the head cycling. Does it run the hole way from right to left side and back? Or does it stuck some where? Please write here where it stopps.
Posted on Sep 16, 2007
Mix-it-up
  • 832 Answers
SOURCE: error messages
same issue:
http://www.fixya.com/support/t294185-brother_mfc_240c_change_unable_50
Posted on Dec 30, 2007
Mix-it-up
  • 832 Answers
SOURCE: Print Unable 50 Brother MFC5460 CN
So dont let me be a withness of murderer:
There is no paper sicking within the machine! The jam had lifted the encoder strip out of the ph. After you have fixed it simppy stick some very thin scotch tape onto the ph cover to avoid further liftings (that will happen quite often...)
same issue: (change the viwing size of your browser to enlage the pics)
http://www.fixya.com/support/t211210-brother_mfc845cw
Posted on Mar 17, 2008
SOURCE: Can Brother MFC 5460 CN scan without the cartridges?
I have one of these and it would not scan with out ink. Wish I had asked the question before purchasing :)
Posted on Apr 02, 2008
  • 214 Answers
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
Posted on May 11, 2008
I have a brother's MCF-255MC printer and i keep getting the message unable to clean 50 I followed the steps in the manual and it still didnt work could you please help me?
How do I clear the message "Unable to..." or "... Unable" ? ' Brother
support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod...eu_as...
Aug 18, 2014 - Unable to Clean (Clean Unable); Unable to Init. ... If the encoder gets markings or debris on its surface, it may cause other problems.
Brother Unable to Clean 50 Error - YouTube
? 0:51
https://www.youtube.com/watch?v=8THfCUgYCMU Jun 9, 2015 - Uploaded by Aceh Com
Printer Brother Unable to Clean 50 Error Cara mengindentifikasi Printer Brother Unable to Clean 50 ...
Clear the "Unable to Clean" Message ' Brother MFCJ4510DW ...
? 1:49
https://www.youtube.com/watch?v=EH3CEA3WbEY
Aug 2, 2013 - Uploaded by Brother Office
Yeah, keep it ... Clear the "Unable to Clean" Message ' Brother MFCJ4510DW, ... assistance, please ...
Printer is displaying unable to print/init/clean 50. Have referred
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Get a Professional Answer ... Have referred to brother manual and there is nothing jammed in the machine. ... To attempt to resolve it, do the following steps created by Brother in this step by step guide to try resolving the error message: ... Unable to init, unable to print, unable to clean, unable 36, error 46, 50 and error 32 are ...
I am getting error:unable to clean 50, was unable to print - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting I am getting error:unable to clean 50, was unable to print - Answered by a ... What is the exact model of your Brother printer? ... For example, MFC-615 ... it is not allowing me to press any thing, I keep getting a beeping noise when I press .... How do I remove error messages, epson wf-2750, PC MS10, I 8/12/2017 8/12/2017.
brother MCF 255MC printer message unable to clean 50 Google Search
Aug 14, 2017 | The Office Equipment & Supplies
Print unable 51 code on brother MFC-5460 CN
paper jam or some sensor error, try to clean the sensor, locate the sensor under the pump, where the printer head park the dis assemble and get the sensor, then clean with water or alcojol..
Jul 21, 2014 | Brother MFC-5460CN InkJet Printer
My MFC-5460 is not feeding the paper. There's no jam...
Remove the paper and invert the printer and give it a healthy shake. just be careful not to drop it.
you may hear whatever is obstructing the pathway, rattling around. Use a small flash light to identify and remove it. Then shake again until all is found and removed.
... the ink jet track obstruct the paper?
Feb 02, 2010 | Brother MFC-5460CN All-In-One InkJet...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
My printer is showing an error
our printer brother mfc 5460 is not printing.....even though there's an ink....how can we fix that? pls help....
Dec 27, 2009 | Brother MFC-5460CN All-In-One InkJet...
Machine Error 51
More than likely you have a bad printhead, if its under warranty brother will pay to have it fixed, otherwise just play baseball with it and buy another one
Aug 22, 2009 | Brother Multi-Function Center MFC-240C...
Help
I say you throw it in the trash
Sep 23, 2008 | Brother MultiFunction Center MFC-440CN...
"Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
Mar 17, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5460CN All-In-One InkJet Printer Logo
152 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
